FP BLACK's life on a stock block?
I have been making 450/400 on a mustang(add a easy 10+% for most DJ) and have been fine... Its the early, and knarly TQ these small turbo's make that will kill rods... The tuner can soften that up a tad... The only thing head studs will do is prevent a blown head gasket and such which really IMO would actually be a half arsed safety valve instead of tossing a rod... I am going to some ARP rod bolts this week cause the stockers over time will stretch and you risk spinning a bearing. $45 is cheap insurance imo.
Ill be installing my 6262 kit this week on the stock block and running 30-32psi on E85 with it and expect my motor to hold it with a solid tune for at least a while.
wow be honest with yourself your going e85 which will net you more power then your going with a power hungry fp black and expect it to be reiable on stock shorty. Good luck with that ideal. you would be better off on 93. if your using e85 turn the boost down tune for maybe 25 psi to keep things safe. the tq number has already been stated in the thread if you want reiable get a built longblock. Your just putting yourself on borrowed time when you double the limits of the stocker. Could it hold of course but just because your neighbor does it does not mean your car will handle it. I hope you plan on saving for a built shorty the second you buy this black with headstuds. that way when you blow it the blow will be softer
Hey Steve, I was talking about Kyle and Bryans cars that had those problems. Kyle told me to get rod bolts as well but I would need Gst to install them. I have 15,000miles on my car so I don't want to rebuild it yet. I actually decided to go with my first choice of turbo/cam combo. I'm just going to go with the BBK-full with FP4R cams. I know that is a bit of a change from a FP Black but I'm going to get faster spool and it will BR easier to restrict the tune for the sake of my block.
Thanks for the input guy's.
i agree with mikey also great turbo but a bit laggy when compared to the green or red..It's also gonna be hard for u to make500 whp on 91 oct hope u have some serious mods done like porting,cams,manifold,etc.etc. if not your are wasting your time and money!The best way to achieve your goal on 91 oct is all the mods i listed also add some meth..
ok good luck..go with a red if u dont wan't more then 550 whp cause it's a waste sometimes i miss the hammer hit from the red......
I'm going with the BBK over the red because believe it or not.....in my area there is more than a few BBK's making the same power as reds with a tad faster spool and more reliable for road racing. Ask Ssteve^. He is making 440~450whp on a mustang dyno on a 03 Evo 8.
BBK's have a good reputation in California.
Well my friend was making 400whp/400tq on a mustang dyno with FP4R's and abosolutly no problems. I don't know much about the kelfords myself. I know one local with a hta35 was having knock issues with the kelfords. Besides everyone saying they make good power that's all I know? Lol
As for porting, I'm on a budget and I'm only trying to collect the key pieces to the build. The only porting I have done is my ex mani.
my friend i think your a little clueless of these turbo's do more research cause the green with e 85 is a nasty turbo!!!!!!!!
