Idle problem after tune
Old Mar 17, 2010 | 02:58 PM
evo4life400's Avatar
yeah idk why he screwed with it...I cleaned my maf and the idle improved but I still get this ticking noise....
Old Mar 17, 2010 | 04:25 PM
Ginglingston11's Avatar
Originally Posted by Evo_Kid
That Idle screw (aka BISS) is NOT suppose to be adjusted unless you use EVOscan to adjust it correct.
Also, the idle should have been fixed in the ROM, not by using the BISS.
I was thinking the same exact thing. I remember on my DSM the idle adjustment screw was a big no-no
Old Mar 17, 2010 | 04:28 PM
I forget since its been a while but what do they recommend to clean the MAF?
Old Mar 17, 2010 | 08:48 PM
i cleaned my MAF and the car still doesnt run right....i have to bring it back i guess....
i just used the stuff they have at NAPA....it says not to use it on Mitsubishis but i searched and found that a lot of people do it with no problems
Old Mar 18, 2010 | 08:56 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Mike I spoke to a few people and you need to change your sig to "GrimmSpeed BCS" BTW that is what is making the ticking noise. Remember it's a MAC Valve and it installs on the frame rail inside the engne bay. So you will hear alot more. I have one too but I have a o2 dump so I don't hear it at all . As for your idle. I found out you do all your own wrench work? If that is the case then check all your vac lines second do a boost leak.
Old Mar 18, 2010 | 09:50 AM
JuniorAWD's Avatar
Thanks for the tuning tip...
I'm guessing that's why my laptop was in the car when it was being adjusted.
Anyway, bring the car by... Sounds like a vacuum leak.
As for the the ticking noise while you pull away from a stop light, that would be the BCS. Sometimes depending when were it is mounted they will be noisy.
Jr
Old Mar 18, 2010 | 01:23 PM
Evo_Jay's Avatar
Jr
I wasnt giving you any tuning tips. And I never said or assumed you adjusted the BISS without using EVOscan.
I just mentioned that is the proper procedure. And if proper procedure wasnt taken, then that may be a problem.
The OP mention he played with the BISS too. So what I said was more directed at him.
Old Mar 18, 2010 | 05:39 PM
hey junior...yeah maybe i will bring it down. thats a good thing to hear if the ticking is just the boost controller....thats a relief
as for the idle...i will check all of the hoses the go from the turbo to the BCS, intake, turbo etc...if i cant figure it out then i will call jimmy and ask
also could i have screwed something up for changing the screw by myself? the idle was just stuck at 2k so i thought it would help
Old Mar 19, 2010 | 06:56 PM
i checked all of the hoses and stuff today...the idle has improved but i still get these moments when i push in the clutch from a slow roll and the car almost dies. it also turns over slowly when i start it a lot. im starting to wonder if its the cam angle sensor or crank angle sensor but i have no clue.
someone give me suggestions!!!
Old Mar 19, 2010 | 09:36 PM
i really cant help you out with the sensor question but as far as the starting problem i had the same thing it was acting up on me a few months after i took the heat shield off the starter and then the starter took a **** on me. i ended up having to replace it even tho the car was only a year old. but if thats not your case then check the starter cable, if thats coming loose, you would have a bad connection and it will cause starting problems
Old Mar 22, 2010 | 09:33 AM
DBallz's Avatar
Did you bring it back to get it diagnosed?
poleclimber63
Lancer Troubleshooting
Nov 2, 2015 11:37 AM
asahlot
10
Aug 20, 2010 06:20 PM
evo4life400
Mar 13, 2010 01:25 PM
aguita
Sep 20, 2009 10:31 PM
ArchieBabes
Feb 23, 2006 08:42 AM
