BG vs Redline
Old Mar 18, 2010 | 05:46 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by 06MREvo
Gears were very knotchy feeling & my 4th gear started to grind shortly after having the Amsoil in there...Didn't have knotchy feeling with Royal Purple & don't have it with BG...never had any 4th gear grind with RP either...& the 4th gear grind @ high rpm shifts isn't nearly as bad with the BG as it was with the Amsoil...
See I'm the oppisite of you I went from oem fluid to BG and after about 5k my tranny felt like crap Then I recently switched to Amsoil about a year ago and it feels great the tranny is notchy when it's cold but when it's warm it smooth as butter. AMSOIL FTW
Old Mar 18, 2010 | 06:48 AM
gamebred26's Avatar
lol i actually use 2 amsoil and one redline mtl...now ...in the tranny.. oem in transfer case and rear diff..
Old Mar 18, 2010 | 11:03 AM
gsrboi80's Avatar
I have used nothing but Pennzoil Syncromesh in my EVO's tranny since the first change. Car has 120k+ on it. Stock Trans and shifts wonderfully
I thought about switching to AMSOIL but at this point I'll stick with what I know works great. I do change it at about 10k intervals
I'll wait till I rebuild and follow the builders recommended fluid
Old Mar 18, 2010 | 01:23 PM
06MREvo's Avatar
I used Pennzoil Syncromesh in my 97 GSX's transmission...worked great...a little over 120k miles & shifted great...& that tranny loved NLTS...car sat right @ 400whp & wtq when I sold it...
Old Mar 18, 2010 | 07:19 PM
dambikeracer's Avatar
Originally Posted by EViR
So their pretty much the same price... which one is everyone using?
Redline 75-90 or
BG Syncro Shift I or II
Just looking for the best
Stay with the OEM till you are putting down 400+ WTQ. I ran the OEM fluids for 50K with no problems. Now that I am above that 400+ WTQ I swiched to Amsoil in the tranny and Redline Shockproof Heavy in the transfer case and rear diff.
At 60k I am going to try Redline 90w in the tranny and Amsoil in the tcase and rear diff. I'm also a Amsoil distributor, that's all I will run in my motor! I also hear that Castrol makes a great tranny fluid!?!
Old Mar 18, 2010 | 07:36 PM
project_skyline's Avatar
I used to run redline MT-90 and lightweight shockproof mixed 50/50.
It was great when racing and driving hard, remained consistant. Cold feeling wasn't so great.
Im currently running AMSOIL MTG and its nice when cold but I've noticed during racing shifts aren't as smooth. I'll run the car a few more times at the strip to see once I get the new clutch in, if things aren't smooth I'll just go back to running my redline mix.
Old Mar 18, 2010 | 09:21 PM
EViR's Avatar
Pennzoil Syncromesh isnt this stuff at autozone, i thought about getting it but it didnt really say anything besides chrysler and stuff, yellow bottel right?
Dont wanna blow my tran up haha
Old Mar 19, 2010 | 05:00 AM
gsrboi80's Avatar
Reason I won't switch at this point don't try to fix what is not broken or stray from what I know works
Yea you can get it a lot of places yup yellow bottle. Pretty much the same formulation as GM Syncromesh from what I hear. It will certainly not blow up your tranny as I said it is the only thing that has been in my trans since the first change. 120k later still on stock Trans
The only thing with it is I def change it out in 10k or less intervals
Old Mar 19, 2010 | 05:05 AM
MrHouse's Avatar
Redline
Old Mar 19, 2010 | 09:44 AM
SeeCoryRun's Avatar
Ive been running Redline shockproof LW in the trans and HD in the TC and rear.... couldnt be happier.
Old Mar 19, 2010 | 10:06 AM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
i run the amsoil fluids in my entire driveline and couldn't be happier i change it every 10k or so and see basically nothing in the fluid and the consistency is pretty much like the stuff new. only thing i did notice is the tranny is a tiny bit notchy when shifting slowly but shifting hard is fine.
Old Mar 21, 2010 | 02:56 PM
detroit pistins's Avatar
my 02:
Switched to amsoil at some point cuz few friends recommended it, and wasnt very pleased with the results, it was very tough getting into 2nd , and overall, the gears felt knotchier.
switched to BG and the issue was resolved.
on a side note: Leith Mitsubishi in raleigh, NC, uses BG for thier evos.
to the op, I recoomend u spending the $100 and get both kinds, run the first one for urself, and if it felt knotchy then switch and report back. gl!
Old Mar 21, 2010 | 03:01 PM
SyZyGy1394's Avatar
Lol at the amsoil pusher saying that amsoil improved drivability. I'm sure just doing a fresh fluid change would do the same thing.
Old Mar 21, 2010 | 03:26 PM
05ah8james's Avatar
Not to get off topic, but which vendor on here has the best pricing on amsoil products?
Old Mar 21, 2010 | 03:39 PM
Jeffs2006EVOIX's Avatar
The post
Really hard for anyone to take any info here on such a subject matter. To many opinions out there.
I am not a distributor, I am not a vendor, I am just a regular Joe who drives a remarkable car.
On my 06 MR, I have tried both the fluids in question. Bottom line? They are both terrible.
Amsoil?? They do have a new fluid devoted for the 6spd that I have not tried yet so I can't say how their fluid is now, BUT when I had my Evo 8, I ran Amsoil and had no complaints.
Currently though, on my MR, I use the Mopar Racing Fluid in my 6spd. Its a 75/85 just like the Diaqueen and can be had a more reasonable cost. It shifts flawlessly and I love it.
The downside is the Diaqueen and the Mopar Fluid is mainly used for Daily Driving. If you Track your car, or even do a few 1/8th mile drag races on the weekend, then I feel the thicker fluid from Redline or BG would be better suited for that.
If you use Amsoil you really can't go wrong, its a good fluid. RP has been used by many users with great success as well and you can buy it at your local Auto Parts store, as is not true with Amsoil. Special Order in most cases.
Currently in my car I use the Following:
Engine: Royal Purple XPR 10/40
Trans : Mopar Racing 75/85
Brake : Motul 600
P/S : Diaqueen
R Dif : Diaqueen LSD
T/C : Diaqueen LSD
Been using this set up in my current Evo for 40,000 miles, with over 300 dyno pulls and have had (knock on wood) not one oil related failure.
Hope this Helps you.
Evo8bg
Jun 1, 2016 01:52 AM
EvoAznBoi
49
Apr 16, 2013 06:29 AM
DrivelineSales
EvoX 'For Sale' Exterior Styling
25
Jan 28, 2013 03:17 PM
dee_yamaha
Mid-Atlantic Region
Apr 12, 2007 06:48 PM
vroomevo
Mar 7, 2007 08:14 AM
