Is there every going to be a company that makes bolt on turbos??
Originally posted by Eric Lyublinsky
to bad. I like Power.
Garrett does not make T3/4's anymore. THey are using all GT series turbos. The GTxxR's are ball bearing. If you have T3/4 than it is made by another company. I myself would run a GT30R for up to 500 HP and a GT35R for 600+ HP but you need a custom manifold to do it. Garrett makes VERY few reverse flow turbos.
Re: Is there every going to be a company that makes bolt on turbos??
http://forums.nasioc.com/forums/show...hreadid=437922
Power makes awsome ball bearing turbos. I had a 1818f in my WRX wagon and I loved it. A little on the laggy side but very nice. They also make a twin scroll for the New age JDM STI so I'm sure they can make a monster 16G based BB turbo that is twin scroll.
I really don't want to do a new mainfold and ext. wastegate. Just want a good BB turbo upgrade. Does anyone have anything in the works.
If Power came out with one I would buy it in a hart beat.
Eric
Eric
I guess a few monkeys missed the part in blue Eric... I don't think they realize how damn many of us want a turbo with hardware that bolts in between the STOCK manifold and STOCK O2 housing... nothing more, nothing less.
Originally posted by evo_dan
In order to have a custom bolt on turbo kit built, for development purposes the manifold, whether stock or otherwise would still need to be provided.
Hmmm, I didn't realize that using an internal wastegate was cutting corners. As long as you can control the boost it makes for a much cleaner installation and much easier to package a kit.
We are also developing a turbo kit, actually it is done. We are just waiting on the manifolds to be cast.
The turbos we are going to offer are going to be Garrett units with custom cast turbine housings with internal wastegates. One thing I am sure of is we have gone faster than any other vendor out there using a 4g63 engine.
The turbo that is on our Conquest powered by a 4g63 engine is internally gated. The car has run 8.7 at 151 mph with this internally gated turbo. It is on a 2g cast iron hand ported manifold. reliability issues with this set-up is perfect. This turbo will also be available for the EVO8. We have made 650 whp with it.
Our turbo kit is going to use the stock EVO8 heat shield and will appear to be very stock to the onlooker.
Good engineering does NOT equal cutting corners.
Take care all,
David Buschur
www.buschurracing.com
Take care all,
David Buschur
Thanks David. As always a professional and intelligent response unlike many other vendors and manufacturers. I agree that results and quality is what is important. The design will follow that. I myself prefer external gate but for some applications it just isn't necessary and increases cost.
Take care all,
David Buschur
Take care all,
David Buschur
Re: Re: Is there every going to be a company that makes bolt on turbos??
Eric
In Timeout
From: My name is Ananda Robinson.Stupid people should be killed. i live in Maryland
Originally posted by 3deep
What about a heatshield?
With any tubular non stock header. you will have tremendous under hood temps. The solution is header wrap or some type of ceramic coating. I recently switched to an equal length header on my dsm. I had everything coated except the turbine housing.
Eric,
speed box from Japan makes a bolt on turbo similar to what power does for subaru. i think RB motoring had one that they were trying on in this thread:
https://www.evolutionm.net/forums/sh...ight=speed+box
let me know if you want one and i can get it for you. (i am also dying to try one out so i will order 2 at the same time for a good price)
Originally posted by blonde
ignore the above post, i don't think that one is ball bearing. i have a catalog at home so i will try to find another one later on.
Eric
I agree with Buschur that an Internll does make a cleaner install, that is not nessecarily cutting corners. The problem I have with internals is that they make the turbo spool slower for 2 reasons.
A) The turbine housing is not nearly as nice. A 4 bolt ballistic Garret unit spools noticeably faster then a 5 bolr bastard flanged garret unit. In addition to that internals ALWAYS leak, while externals provide a perfect seal. Internals are always at the sacrifice of spool.
B)In addition to that internals ALWAYS leak, while externals provide a perfect seal. Internals are always at the sacrifice of spool.
So yes internals do have their benefits, they are cost effective and you may think of them as a cleaner install, although I like external looks, but they are NOT equal.
In addition, the conquest example is silly. The larger the turbo and the more boost you run, the less gate you will need. Its the street cars running lower boost levels that you need to control.
My bad. I miss read your post.
