RPM jumps and goes down by 200 on WOT
Old Mar 29, 2010 | 06:47 AM
bigric09's Avatar
Can you please stop arguing... it is your clutch !!!!
Old Mar 29, 2010 | 07:19 AM
596736's Avatar
Originally Posted by dvd_mi
It does not happen when I am using clutch and shifting. When I accelerate from 1st gear to the 5th with high rpm shifting everything is ok all the way to the end (5th). But it happens only when i am not touching clutch and i am driving for example 50mph on the 5th and then I hit the gas pedal to the bottom and after few seconds rpm goes down by 200 and from there it accelerate OK againg.
When ur in that gear and crusiing at 50mph this will be more engine load than a lower gear. This will cause ur clutch to slip as opposed to when ur in a lower gear with lesser engine load on the drivetrain. Bottom line is you need a new clutch.
jameswwt
10
Sep 18, 2011 12:53 PM
xhomm02
40
Mar 19, 2011 12:21 PM
morfhious3
11
Jul 13, 2009 10:46 AM
EricH
14
Feb 9, 2007 09:36 AM
zlancer
Lancer Aftermarket Forced Induction Tech
Oct 26, 2002 09:16 PM
