Amsoil Users for the T-case and Rear Diff
Old Apr 8, 2010 | 09:47 PM
  #61
dambikeracer's Avatar
Change of heart, I think I'm going to run the 75w-110 over the 75w-140. The only two companies that I can find that make the 110 are Amsoil and Joe Gibbs Racing. I think it will serve me well. I'll let you know what I think in less then 2k miles!
Old Apr 9, 2010 | 12:14 AM
  #62
u189961's Avatar
I've been using SVG Severe Gear 75W-90 for my TC and read diff for the last 8 months or so. You could definitely tell the drive train felt smoother. On oem fluid, I was getting a very slight tc whine but after switching to the amsoil svg, it actually went away. thought i would chime in. gl
Old Apr 9, 2010 | 04:38 AM
  #63
apagan01's Avatar
Originally Posted by madnezpr51
with the 05 using lsd oil in the T-case is amsoil made with an additive for that also? and what would be recomende for and 05 evo with ACD on bolt ons with stock turbo?
yep SVG 75W90 is already ready with LSD additives,,, id say to run 75w90 for your set up as i take it you aint over 450 hp on the stocker,,, SVG 90 is a pretty stout oil and holds up to good abuse
Old Apr 9, 2010 | 04:42 AM
  #64
apagan01's Avatar
dambikeracer,,,, since you started this thread and i see how well it structured itself,, i think you should provide some data once this is all set and done, if you decided to go with Gibbs oil, lets get a sample of that when you drain to see where it sits at that point and i can assists with the analysis labs and cost and you can pick the lab you desire.
i would also like to get a sample of SVG i can manage that one though.
let me know i think it would be good comparo for this thread.
Old Apr 9, 2010 | 07:55 AM
  #65
RunThat's Avatar
Good idea! I run all Amsoil fluids myself in everything I drive, especially my Evo, and I am curious too about the "proof in the pudding", so to speak.
Old Apr 9, 2010 | 08:00 AM
  #66
Im'not going to run Joe Gibbs, I'm amsoil all the way. Better protection then the 75w-90 and not as heavy as the 75w-140. It's a lot closer to the 140, so it should be perfect for my set up.
Old Apr 9, 2010 | 08:09 AM
  #67
RunThat's Avatar
I just got the 75-140 due to my higher hp and torque levels with the FP Black and my rather "spirited" driving It's going in this weekend, so I will report back with my results with it as compared to the 75-90 I've been using.
Old Apr 9, 2010 | 10:00 AM
  #68
apagan01's Avatar
good
however if understand you , bassically you are saying you will run SVG 75W90 ?
Old Apr 9, 2010 | 07:41 PM
  #69
Boricua_Evo's Avatar
I use SVG Severe Gear 75W-90... Runs smooth. I've been driving with it for about 30K... As a matter of fact I need to change my fluids some time this month or next!!!
Apagan01, I will be contacting you soon.
Old Apr 10, 2010 | 09:35 AM
  #70
good
No, the 75w-110 (SVT)
Old Apr 10, 2010 | 10:47 AM
  #71
apagan01's Avatar
got ya !
Old Apr 10, 2010 | 10:48 AM
  #72
apagan01's Avatar
i remember you were one of the 1st customers.
Old Apr 10, 2010 | 08:12 PM
  #73
jdmdc2r01's Avatar
I use amsoil in all of my drivetrain. 75-90. 354whp. Street/weekend track days. Feels great, shifts smooth, no noises, never had a problem. I purchased from (apagan here on Evom) and i highly recommend this product and the seller!
Thanks,
-e
Old Apr 11, 2010 | 10:05 AM
  #74
apagan01's Avatar
I want to hear feed back from Amsoil user that are using gear oil in the t-case and rear diff only! With the last drain I used redline shockproof heavy which is a 75w-250. Now I wanting to try the Amsoil in the drive line, and here's what I'm looking at:
SVT Severe Gear 75W-110
SVO Severe Gear 75W-140
SRN Severe Gear SAE 190 (this is what I was thinking of using)
SRT Severe Gear SAE 250 (which AWD Motorsports uses)
I put 26k miles on my car last year and Drag Race every chance I get! I launched 150+ times last year.
I think you had enough feed back sir
Old Apr 11, 2010 | 08:23 PM
  #75
I was hoping to find more people running the 75w-110, 75w-140 and the SAE 190. It seems that most are running the 75w-90 and I was wanting something a little bit thicker.
But after doing more research of my own, like I always do... I made up my mind to run the 75w-110
