overheatingevo 8 need help ideas
Old Apr 2, 2010 | 02:05 PM
balnout's Avatar
2003 evo 8
temp is fine when im driving once i stop temp starts to rise, main an is running but slim fan is not any ideas would help.
Old Apr 2, 2010 | 02:11 PM
Falcon350z's Avatar
I believe there is a switch (a coolant temp sensor) that turns the fan on and off - replace it. It's a pretty simple job. This should fix the fan coming on and off... if it doesn't, then you should check out this thread:
https://www.evolutionm.net/forums/ev...an-switch.html
Here is a link to autozone's coolant temp sensor: Autozone
Also, replace your radiator cap. A good seal is important, and the $12 bucks for a new cap is worth the investment if you've seen overheating issues... typically, if you rev on the motor while your stopped, and the temperature DROPS, it's a good sign the radiator cap is bad.
Old Apr 21, 2010 | 01:25 AM
MR. EVO MR's Avatar
Check the radiator cap, thermostat. also is there fluid in the overflow?
Gl
Old May 12, 2010 | 11:43 PM
gqcode's Avatar
Veteran: Air Force
It probably your thermostat stuck close! I had the same problem this year i had to order from the dealership since autozone and other didn't have the right one for the evo. Extreme PSI sale it for $22
Old May 13, 2010 | 11:39 AM
talentsearch301's Avatar
Originally Posted by balnout
2003 evo 8
modded or stock?...
When I was in Maryland samething happened to me... had to go to a bigger rad and fan
Old May 13, 2010 | 01:50 PM
Fourced4cyl's Avatar
Coolant flow prob. Mine is doing the same thing and am suspecting the thermostat like mentioned earlier. Since mine is a Cali track car im bypassing the thermostat.
honki24
Jan 11, 2024 03:27 PM
Trustz
May 13, 2013 06:47 PM
arcustoms
Jul 20, 2012 04:46 AM
mikiblueeyes
Nov 22, 2006 09:45 PM
evo8dad
33
Jun 5, 2005 05:01 PM
