stock block and head with Precision 6265 turbo
Old Apr 4, 2010 | 12:17 PM
CrashD's Avatar
hello guys,
need a little advise for u guys....
i have a evo 9 MR JDM with:
stock block and head,
Precision Billet 6265 turbo with full race twin scroll manifold and downpipe,
1200 cc injectors.
Haltech Sport 2000.
rpm going to 8700 with 1.9 bar of boost.
is this setting safe for the stock block and head, or do i need to change the internals???
i.e pistons, rods, crank, spring retainers and so on???
Old Apr 5, 2010 | 12:03 AM
CrashD's Avatar
anybody??
Old Apr 5, 2010 | 11:51 AM
Levar's Avatar
Veteran: Army
I would certainly upgrade my springs/retainers to push her to 8.7K. There have been both good news and bad news stories of guys using the stock block with upgraded T3/T4 turbos. It all depends on how much torque you are seeking. I threw a rod at 411wtq before my stock block "gave up the ghost". I'd submit to ask your tuner for recommendations.
Old Apr 5, 2010 | 12:04 PM
RockmanX's Avatar
that sounds about perfect to me if your over 420tq you need to consider highly going built block of some kind and btw as he stated reving that high you better get youself some spring and retainer upgrade.
Old Apr 5, 2010 | 12:21 PM
SBR INC's Avatar
ARP head studs, springs, retainers, and most of all - a good tune up.
Old Apr 8, 2010 | 01:25 PM
CrashD's Avatar
ok thanks for the advise:
so i have bought the flowing :
1.evo 9 Cometic Head Gasket
2.SUPERTECH DUAL VALVE SPRINGS RETAINERS KIT
3. ARP HEAD STUDS.
do u think with these ill be safer with my boost??
and one more important thing i just have to ask, do i need to change the pistons and rods as well?? and the crank???
answers will be very helpful
thanks.
Old Apr 8, 2010 | 01:33 PM
4g63smokinall4s's Avatar
ditch that head gasket.. but everything else you should be alright!
Old Apr 8, 2010 | 01:46 PM
CrashD's Avatar
but to change the studs the head has to be lifted innit? so i cant reuse the old head gasket, so y not put a better performance one!
Old Apr 8, 2010 | 02:10 PM
CrashD's Avatar
Old Apr 8, 2010 | 02:47 PM
MrHouse's Avatar
Changing pistons,rods and crank will let you handle more boost. A ported head would help you too. Is your intake manifold and tb stock?
Old Apr 8, 2010 | 02:53 PM
Mellon Racing's Avatar
I used the oem head gasket, no problems up to 45psi FWIW. I have many customers at 420tq 500awhp area on the stock shorty/head but I do limit rpm to 8000 and keep knock under control for safety.
Old Apr 8, 2010 | 03:00 PM
MrHouse's Avatar
I would rev 9500 if I was running billet 6265
Old Apr 8, 2010 | 03:14 PM
CrashD's Avatar
yes the manifold is stock, what a Tb??
but i dont want to go higher than 1.9 bar of boost and rpm more than 8700, so u think im ok with stock pistons , rod and crank???
Old Apr 8, 2010 | 03:22 PM
CrashD's Avatar
so u think using cometic gaskit is good idea??
FIY my Rpm have been lowered to 8500 with no knock.
u think the internals will take this amount of boost and still be safe???
Old Apr 8, 2010 | 03:32 PM
MrHouse's Avatar
Nothing is safe if tune is not correct. If I was you, I would change internals to be on the safe side.
