exhaust is leaking boost
Old Apr 8, 2010 | 12:28 PM
Gary@MellonRacing's Avatar
still leaking all the air thru the muffler even by turning the crank ..
Old Apr 8, 2010 | 01:07 PM
APM Racing's Avatar
I'm not joking i have seen this problem a few times. People turn up their boost and forget to zip tie their vacuum lines on . The EGR line loves to pop off when you do a boost leak test it will not be able to hold any pressure and when you listen, you will hear the leak coming out of the exhaust system. I think some people maybe confusing a boost leak test with a compression test. Good luck!
Old Apr 8, 2010 | 03:46 PM
bbyevo8u's Avatar
hmm why didnt the psi stop at the TB plate??
Old Apr 8, 2010 | 09:49 PM
sparky's Avatar
Originally Posted by sparky
.... Isn't the boost leak test done directly to the throttle body?
Duh! I guess that I was really drunk last night Wow, someone else pointed out that boost leak tests are done pre-throttle body. Of course that person is right. Just too meany brews for my own good
4b11slayer
15
Oct 22, 2016 09:09 AM
ddlopresti
Jul 28, 2015 12:57 PM
03evoxxx
Jun 16, 2010 01:22 PM
ganghyung
Nov 1, 2009 11:09 PM
freakitgood
Mar 19, 2009 12:13 AM
