Removing acd system and installing non acd transfer case
Old Jan 8, 2013 | 10:52 AM
  #31
blowngasket's Avatar
Originally Posted by NOMIEZVR4
Just to be sure, when doing the swap just a non-acd t-case is needed?
Where is the acd ecu located??
i beleive there is one located foward of the ashtray in the center consol.
  #32
Roadrunr's Avatar
Correct, just swap transfer cases.
ACD Computer is to the right of the glove box.
Old Jan 8, 2013 | 02:39 PM
  #33
4g63evoeight's Avatar
removal/unplugging of the acd computer turns off the ACD lights.. is that correct?
Old Jan 8, 2013 | 02:48 PM
  #34
Roadrunr's Avatar
YESSSSSSSSSSS
Old Jan 8, 2013 | 04:49 PM
  #35
YESSSSSSSSSSS
perfect. thanks Don. your IX is AMAZING
Pete
Old Jan 22, 2013 | 04:22 PM
  #36
KOOLER's Avatar
just done the swap today
eudm evo9 gsr
6 speed tranny -> 5 speed rs
acd -> non-acd
ayc -> rs rear diff
one question so far... my t-case has open front diff. is it OK for tarmac? or should I throw in something stronger?
Old Nov 5, 2013 | 12:04 PM
  #37
blackandredgts's Avatar
Can you just put a non acd t/c on an acd t/c?
Old Nov 5, 2013 | 12:10 PM
  #38
T/c cover on a acd t/c sorry left out the cover part
Old Aug 12, 2015 | 09:47 PM
  #39
6spdlegend's Avatar
All of these answers are somewhat confusing/contradicting. It still isn't clear to me if it's safe to drive with my acd pump removed IF I PLUG THE LINES running to the t case?
Old Aug 13, 2015 | 06:50 AM
  #40
I think it was explained that you'd pretty much have a front wheel turbo honda if you did that.
Mine was front wheel with no rear when my acd pump failed. I went with a rs tcase and quafie lsd best move ever on my ix, even replaced the gauges and Blacked out the button so it looks as acd when never even a thought in my car
Old Aug 15, 2015 | 03:55 AM
  #41
kikiturbo's Avatar
yes it is ok to drive like that... you will still have 4wd just no centre diff lock so the car will like to understeer more and you will get more wheelspin in the wet..
Old Aug 15, 2015 | 06:57 AM
  #42
6spdlegend's Avatar
Thanks for the reply. But if my acd pump is shot right now it's essentially the same thing correct? meaning i already lost centre diff lock until i fix the pump?
Old Aug 15, 2015 | 07:06 AM
  #43
kikiturbo's Avatar
exactly... you can remove the pump and drive the car without it.. no harm will be done to the transmission..
ugatalane
Nov 25, 2016 02:54 PM
EvODavO
Nov 17, 2016 07:38 PM
BuiltS13
18
May 23, 2016 08:04 AM
k2evo
Mar 10, 2016 02:46 PM
slvrevosd
Oct 29, 2015 01:56 PM
