need help, threw codes p335 &340
Well i was driving today to the store when my car just dies out of no where, i pull over and try to start my car again and it just turns over. I pulled the codes and i got a p 335 n 340. I read that it could be a dying battery but my battery is fairly new. I called a friend to give me a jump just in case but nothing, just turned over. Im having my car towed to my house soon any ideas what it could be? luckly it happened 1/4 mi from my house.
Very common Evo problem. (same thing happened to me) I replaced my Crank and Cam sensor, got a tune from Sean Ivey and it's perfect!!! Replacing the cam sensor takes 2 minutes, replacing the crank sensor........2 hours if your lucky!
Hope this helps, Sean
ya it jumped timing, its off by 2 teeth, would that mess anything up? im just gonna get it towed to a mechanic to get the timing belt changed, i dont want to mess anything up.
would it be ok to buy the pulies n tensioner etc from autozone n buy the timing belt oem? or is it best to buy everything oem? by the way it looks like it only skipped 1 tooth, and i was going about 20mph when it shut off so hopefully nothing else is messed up
Those codes are fairly common. Could be from moisture, etc. I have seen them thrown after people going through touch-less car washes. As far as your timing belt picture, If indeed it did skip, I wouldn't drive the car. Also a leak down test would be good to see if it maybe bent a couple of valves.
Ozrally-king
Lancer Troubleshooting
Sep 16, 2014 11:24 PM
