Looking at act clutches, couple of questions.
Old Apr 21, 2010 | 11:46 AM
Skott2k's Avatar
Ive got an act hdss as well with a resurfaced flywheel and its working out great. Plus it only costed 1k total for resurface/clutch/install
Old Apr 21, 2010 | 11:49 AM
assaultman2004's Avatar
Same here!
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I have the ACT HDSS it holds the power and Tq just fine on a pull but as soon as I get any heat in the clutch I get lockout issues 6500rpm+ I'm making 470 and 400 tq. The ACT was perfect when I was on stock turbo but now it gets thumbs down all the way
Old Apr 21, 2010 | 11:50 AM
EvolutinIX's Avatar
I have the HDSS, rated at 508 ft/lbs, 32k not one issue. Pedal is a bit stiffer than stock great for a dd. I would resurface the stock flywheel, weight savings isn't worth it, with a lighter flywheel your actually hurting yourself. When you disengage the clutch to shift a lighter flywheel is going to drop in rpm's faster, obviously not what you want in between gears. Just my .02, good luck with your choice!
Old Apr 23, 2010 | 08:21 AM
rgar's Avatar
I don't think I can resurface the stock flywheel. I had a twin put in and don't have the stock assembly. Would I be able to resurface the flywheel that came with my twin? Either way I will probably just get an act streetlite anyways, worth the extra money to be safe.
Old Apr 23, 2010 | 09:09 AM
turbolarry's Avatar
No. The flywheel that the twin disk uses is not compatable with an ACT.
I have a streetlite flywheel, but now wish I had gone with the prolite.
Old Apr 23, 2010 | 10:00 AM
rgar's Avatar
Why? doesn't the pro-lite affect driveability?
Uscbryan
May 22, 2015 08:21 AM
Kee1pride
18
Nov 8, 2014 03:25 PM
speedfreak24
20
Aug 13, 2014 05:56 PM
Piro Fyre
14
May 9, 2011 08:55 PM
beemerfreak
Aug 22, 2007 07:00 PM
