Clutch pedal height issue
Old Apr 19, 2010 | 08:19 PM
RyeLou's Avatar
I know about the adjustments you can make to the back, that isn't my issue. The symptoms are similar to if the adjustment wasn't tight though and the pedal would slip down further. I can shift the car at all times without issue, but the pedal height changes. When it's lower if I put my foot on the under side and pull up with my toe, it will reset to the higher point. It doesn't slip back down by pushing on it but just over time it will. Sometimes it's a few hours other times it's a few minutes. I don't know exactly how the slave/master cylinders work, but that's my assumption is I have a bad seal somewhere and fluid is getting to where it shouldn't.
Anyone have any ideas?
Old Apr 19, 2010 | 09:16 PM
javicracer's Avatar
you need to adjust the height and bleed the system.
Old Apr 20, 2010 | 09:02 AM
RyeLou's Avatar
I'll give that a try. I guess it could be something that simple. I just assumed the worst, ha.
Old Apr 20, 2010 | 10:01 AM
gone2pimp's Avatar
I recently have the same problem. My clutch was installed 2 years ago. Every thing was going smoothly till a few days ago. My clutch pedal wasn't coming back up all the way. I would come up half way. I can still drive the car it just feels odd. Can anyone explan this to me
Old Apr 20, 2010 | 02:24 PM
RyeLou's Avatar
I could have mentioned, but my clutch is stock.
Old Apr 20, 2010 | 02:57 PM
T2Small's Avatar
Sounds like air in the master to me. Try a complete bleed of the clutch line.
Old Apr 20, 2010 | 03:29 PM
RyeLou's Avatar
I printed off the instructions from Mitchell. I haven't looked at the car yet though...haven't had time. Where is the bleeder screw they're talking about?
Old Apr 20, 2010 | 03:52 PM
zx40's Avatar
My car does the same thing, but it only does it every once in a while. Like you said though, I just lift it up with my foot, and it works perfectly fine for a while again.
Old Apr 20, 2010 | 06:40 PM
RyeLou's Avatar
Maybe it's the Michigan roads knocking it loose
