max power on 1000cc's and single walboro
Old Apr 24, 2010 | 02:37 PM
black E's Avatar
whats the max power that PTE 1000cc injectors FPR, fuel rail and a single walboro will support on 93 Oct ?
Old Apr 24, 2010 | 02:39 PM
Mellon Racing's Avatar
about 500awhp
Old Apr 24, 2010 | 02:47 PM
black E's Avatar
Thanks^^
how about if you add a FPR and a fuel rail?
Old Apr 24, 2010 | 02:54 PM
Originally Posted by black E
Thanks^^
I'm at 700awhp with a stock regulator so I can tell you that would be a waste of money, the rail may not be of benefit a that level either. If you need enough fuel for over 500awhp on 93 octane I suggest the BR twin walbro and 1000cc that's enough for nearly 700awhp without a fuel rail. I didn't do a fuel rail until I converted from Q16 to e85 and at that point I also went from 1000cc to 1650cc.
Old Apr 24, 2010 | 02:56 PM
legal-z's Avatar
i made 553 whp with a walbro, ams rail and stock fpr w/1000cc injectors. don't know if the rail made any difference.
Old Apr 24, 2010 | 03:14 PM
Ted B's Avatar
With gasoline, a single Walbro begins to lose line pressure around 525-550whp, as has been documented here some time ago. I've seen 600whp eeked out of a single Walbro and 1000cc injectors, but what's happening is the large injector size is being used as a band-aid to overcome the dropping rail pressure (which makes atomization quality suffer). An aftermarket rail and FPR will not make one iota of difference as Mellon noted.
For anything over 550whp with gasoline, a dual pump fuel system becomes the smart play.
Old Apr 24, 2010 | 03:28 PM
right, I've got some customers at nearly 550awhp on 93 with 1000cc but the fuel map starts looking funky where I'm having to overcompensate at high rpm and that can cause some odd rich on shift issues you don't want. That's why as a rule of thumb I suggest twin walbro for 500+ needs.
Old Apr 24, 2010 | 03:45 PM
black E's Avatar
thanks guys, i'll get the double pumper.
Old Apr 24, 2010 | 04:22 PM
From 3 to E's Avatar
noob question: how hard would it be to go from a single walbro (which i currently have) to a double setup? could i just buy a second pump, or would it be easier to buy a pre-made double-pumper from buschur, etc.?
Old Apr 24, 2010 | 04:29 PM
NitrousOxide's Avatar
Im on BBK full with GSC S2, walbro, 780cc, and CBRD intercooler + all the boltons (should be around 400-440whp based on dyno).. My tuner said that it would be risky if I dont have an FPR, or, I should have a fuel pressure guage to watch out (something i cant recall or understand) to be on the safe side.. Is that true??
Im on RON 98 BTW!!
ThanX
Old Apr 24, 2010 | 04:50 PM
Ted B's Avatar
By the time you would go through the hassle of doing it yourself, you'd probably wish you had just bought the setup. The price of convenience in this case isn't that much.
Originally Posted by NitrousOxide
My tuner said that it would be risky if I dont have an FPR ...
I suggest you find another tuner, because this one is already feeding you erroneous advice.
Old Apr 24, 2010 | 04:53 PM
ok thanks for the heads up. im planning on getting an hta3586 (or something in that range) and wasnt sure if getting 1200cc injectors would be enough for pump gas and possibly meth. sounds like I'll be cutting it close..
Old Apr 24, 2010 | 04:56 PM
Ted B's Avatar
No, 1200s would be fine for pump gasoline. Methanol injection lowers the injector duty, so that isn't an issue. Now, if you were going to use E85, you'd want at least 1450s.
Old Apr 24, 2010 | 05:07 PM
Thank you very much for your coment!!!
Hes the physical tuner, not the one cracking the ECU!! I wanted to tune it through email, tactrix cable by one of the tuners here at Evom, but its a hassle apparently, as they will not really know how to fine tune my car due to the difference in fuel, humidity, overall weather etc!! in addition to the fact that I might get dumped after the first basic tune!!
So im forced, not a hero!!
Old Apr 24, 2010 | 05:14 PM
well its not the injectors im worried about.. im making sure that the fuel system could sustain pressure at 600+awhp. ill be upgrading from my 780's right now, so ill just buy whatever size can flow enough volume.
so do you think i could run E85 on a single walbro and larger injectors (say 1600's?) or would i need a double pumper at that point for sure?
