max power on 1000cc's and single walboro
Old Apr 25, 2010 | 06:06 AM
  #31
RunThat's Avatar
Originally Posted by bbyevo8u
how do you mod the walbro pump and how does it help?
Here you go.
http://www.driven2modify.com/showpos...15&postcount=1
Old Apr 25, 2010 | 06:07 AM
  #32
Mellon Racing's Avatar
Originally Posted by NitrousOxide
Im on BBK full with GSC S2, walbro, 780cc, and CBRD intercooler + all the boltons (should be around 400-440whp based on dyno).. My tuner said that it would be risky if I dont have an FPR, or, I should have a fuel pressure guage to watch out (something i cant recall or understand) to be on the safe side.. Is that true??
Im on RON 98 BTW!!
ThanX
your tuner doesn't sound familiar with evos or just wants to sell you something you don't need.
Old Apr 25, 2010 | 06:34 AM
  #33
Chele's Avatar
I am a bit confused. I have used the formula to calculate required injector size for desired HP and if I am looking for 650hp, I calculated 1200cc injectors. I have also read charts from injector manufacturers that doesn't match what some of you guys are saying. Can someone explain this in more detail maybe? How can you reach 700 hp from 1000cc injectors?
Old Apr 25, 2010 | 06:36 AM
  #34
You could install 2000cc injectors but if you don't have enough fuel pressure behind them the size of the injectors opening doesn't help the situation.
Old Apr 25, 2010 | 06:39 AM
  #35
Chele's Avatar
I understand the fuel pressure thing. I have the walbro with an inline bosch and 1000cc injectors now. I thought that since my goal was 650 on pump gas, I'd require larger injectors. (based on the injector sizing formula) It would be nice to reach my goal without spending money on larger injectors.
Old Apr 25, 2010 | 06:41 AM
  #36
injector sizing formulas can be confusing especially when you don't know the real BSFC and they are talking about flywheel hp.
Old Apr 25, 2010 | 06:43 AM
  #37
also to be clear, when I hit 700awhp on q16 with twin walbro and PTE 1000cc, the AFR was too lean and IDC's were through the roof so I wouldn't suggest stretching it that far.
Old Apr 25, 2010 | 06:50 AM
  #38
Chele's Avatar
O.K. Cool. Thanks for the info Mellon.
Old Apr 25, 2010 | 08:02 AM
  #39
bbyevo8u's Avatar
Originally Posted by RunThat
is that how everyone's modding there walbro?
is the 044 an in tank pump that replaces the walbro i have now?
Old Apr 25, 2010 | 08:46 AM
  #40
Ted B's Avatar
No, the Bosch 044 is an external pump. You would use one in addition to the in-tank pump.
Old Apr 25, 2010 | 09:00 AM
  #41
n2oiroc's Avatar
you can run one in tank, but its rather large. bosch also makes an 040 that is shorter and for in tank use.
Old Apr 25, 2010 | 09:11 AM
  #42
High_PSI's Avatar
Do you have an issue with the stock FPR being over run and base fuel pressure sky rocketing and then not being a static rise based of Boost pressure?
dsmchiz
Aug 29, 2015 10:52 AM
MrHouse
Jul 24, 2014 06:18 PM
u189961
Sep 26, 2012 01:47 PM
500evo
Apr 16, 2012 02:00 PM
scorke
Jul 6, 2007 12:11 PM
