Twinscroll Vacuum Line Routing??
Old Apr 27, 2010 | 10:45 AM
EVOkeith's Avatar
Could someone explain how to route vacuum lines on a twinscroll with two wastegates?
Also what size hose is usually used on wastegates?
Should I go 5/16" or 1/4" barb fittings? What is the standard size shipped with most aftermarket wastegates and BOV's?
Will be using an AEM boost solenoid with an AEM EMS.
Thanks!
Old Apr 27, 2010 | 11:07 AM
gsrboi80's Avatar
I use the lower port over to my MBC. For dual WG's you can just T the Line as I've seen it set up on most cars
Old Apr 27, 2010 | 11:38 AM
EVOkeith's Avatar
Ok cool.
Probably should have said I plan on running a EBC.
The AEM boost control solenoid with an AEM EMS to control boost.
How would I route this. Sorry new to this.
Old Apr 27, 2010 | 12:26 PM
0100's Avatar
Veteran: Army
I will give this a shot. I hope this helps and I hope the EVO GODS will correct this if it's wrong.
Did this in less than 5 min so don't laugh.
I would also like to know which is correct the T setup or X setup with TS?
My guess is X but anyone know for sure...
Old Nov 16, 2011 | 12:08 AM
avex821001's Avatar
bump, anyone knows?
Old May 23, 2014 | 07:51 AM
maknuge's Avatar
bump instead of making new thread...which way is correct?
Old May 24, 2014 | 01:25 PM
BBoNZ's Avatar
I cant say im an expert, but in my eyes both of those are exactly the same. One just with an extra t piece.
Old May 24, 2014 | 03:23 PM
RSMike's Avatar
to help reduce partial throttle surge, make the pressure source for the wastegate actuator from the intake manifold
Old Nov 3, 2014 | 10:25 AM
maknuge's Avatar
what size hose and barb fittings?
Are those hose routing diagrams correct?
evo8lento
Oct 18, 2016 09:22 AM
Ekoy
13
Apr 12, 2016 05:32 PM
tscompusa
Feb 10, 2016 06:12 AM
leetEVO
Dec 10, 2014 02:55 PM
Full-Race.com
Mar 8, 2011 08:18 AM
