aem ems/ buschur cop cdi/ no spark
Old May 1, 2010 | 04:46 PM
yellowevo82's Avatar
installed my buschur cdi cop , hooked the positive side of the m&w box to the positive side of the battery, hooked the ground side to the ground on the battery (got a spark as soon as this touched) .. went to fire up the car and nothing.. so we took the plate off the car and grounded one of the spark plugs to the manifold and we got zero spark.. any ideas? crank and cam sensors are brand new!!
Old May 1, 2010 | 05:16 PM
David Buschur's Avatar
Check the inline fuse for the COP.
Old May 1, 2010 | 05:36 PM
fuse is good dave...
Old May 2, 2010 | 07:54 AM
bueller?
Old May 2, 2010 | 07:59 AM
n2oiroc's Avatar
does the m&w box have a fuse seperate from the inline one? did you check all the fuses on the car? take a good look ad see if anything else isnt working.
Old May 2, 2010 | 08:07 AM
thats what dave asked, yes it has a seperate fuse n yes its still good..
Old May 2, 2010 | 08:13 AM
n2oiroc's Avatar
throw the stock ignition back on to make sure its something with the cop.
Old May 2, 2010 | 08:26 AM
wish i could ha lol sold it .. going to have to borrow my buddies or something
Old May 2, 2010 | 08:32 AM
n2oiroc's Avatar
thats what i would do at this point, some time weird stuff happens with electrical work. i had an aem ignition upgrade fry the ignition drivers in the ecu before.
Old May 2, 2010 | 10:51 AM
and what the ecu is bad?
Old May 2, 2010 | 03:53 PM
itzwolf's Avatar
The M&W box has a diode that can go bad... I've had one fail once but was covered under warranty. The fact the OP got a "spark" when connecting makes me believe that it could have blown.
Old May 2, 2010 | 07:52 PM
well the box sparks on the negative side of the battery when i go to connect it, but no spark with the plugs
Old May 2, 2010 | 11:12 PM
red03evo's Avatar
when you have the key to the on position do you see the red light on the CDI box light up? Are the coils all the way down on the plugs? Everything plugged in? Sorry for the easy questions but the smallest things can sometimes stand in your way.
Old May 3, 2010 | 09:51 AM
Cam and crank sensors can both cause the car to not have spark. Dan is right, is the red light lit up on the end of the CDI box? If so there is probably a problem elsewhere.
Old May 3, 2010 | 02:11 PM
dave both of them cam n crank were replaced months ago.. the car started up on stock ecu.. im going to have to check the box like u said i dint even see a light on the box, but i will have to check that and my fuse panel...
