4.111 Final Drive
Old May 4, 2010 | 01:25 PM
zedevo's Avatar
4.111 Final Drive
Hey Guys , Any one tried the 4.111 on the Track ? Can you pass the 1/4 on 4th gear ?
Thank u ,
Old May 4, 2010 | 01:31 PM
fugiwara's Avatar
Thank u ,
you can pass 1/4 with regular 5 sp gear box...
Old May 4, 2010 | 01:42 PM
zedevo's Avatar
But i have a 4.111 , I dont want to shift to the 4th before the finish Line .. Any one try it ?
Old May 4, 2010 | 02:21 PM
Svendiesel's Avatar
https://www.evolutionm.net/forums/dr...shift-5th.html
A quality read on the 4.11 final drive.
Almost every Evo drag car in existence with a manual gearbox shifts to 4th, the goal is not shfting to 5th.
Old May 4, 2010 | 05:19 PM
goldtooth's Avatar
thanks for the link, good stuff
Old May 4, 2010 | 06:44 PM
awddyno's Avatar
What set up do you have? What is your goal ET?
Watch the vid on my sig. thats in 4th gear all the way.
Old May 5, 2010 | 04:53 AM
zedevo's Avatar
^^ Thanks for the link guys , Actually i Rev at 8100 RPM ... Ill try it very soon ... Ill shift into the 4th Gear in few Meters before the Finish Line ... :s I hope No .... Other wise i have the shift fron the 1st to the 4th on 7800RPM ...
Any More Info or Idea ?
Thanks a lot ...
Old May 5, 2010 | 05:16 AM
zedevo's Avatar
2.3l
35r,
BR 4.5'' FMIC
BF Cams
18'' Advan RS
Stock ecu
Hypertune Intake
Hypertune T/B
Hypertune F.Rail
Btw Great Video u have Buddy
Old May 5, 2010 | 05:21 AM
zedevo's Avatar
Ur on Stock Final Drive ? :/
Old May 5, 2010 | 09:56 AM
icantdrive75's Avatar
I don't see how you're even considering not shifting to 4th. You'd have to do 9,500 rpm in 3rd to do 120, and that's if you only wanna run 11's.
With the 4.11 gears you're only hitting 103 mph in 3rd. So yes, you have to shift to 4th or blow something up. 4th gear will get you over 140 at your RPM.
If you want to stay out of fourth, you'd need to build a 2.0 or 2.1l and go 10k, probably closer to 11k rpm. Even if you went with 3.73s you'd only be getting to 120mph.
Old May 5, 2010 | 11:52 AM
zedevo's Avatar
100% i know , Here's My speed @ 8100 rpm
51 mph
74
100
135
Old May 5, 2010 | 12:00 PM
Well then is your question now where you will have to shift into 4th at? You'll hit 4th right around the 1/8th mile, so about 200 meters before the finish.
Old May 5, 2010 | 12:02 PM
zedevo's Avatar
^^ Ok thanks Bro ...
nikush
Oct 25, 2018 04:17 PM
kazx9r
16
May 11, 2016 10:20 AM
Pirana
22
Jun 18, 2015 04:06 PM
giangi
Jun 16, 2013 07:20 AM
nikush
Apr 25, 2013 05:26 AM
