evo FQ meaning
evo FQ meaning
i have some questions for you....
what's the ''FQ'' ,mean on evo's?
is there a factory that make only ''FQ'' or is the same factory that make GSR's etc?
what's the difference between the FQ's?
is there any evo IX with non-aluminium roof?
what's the ''FQ'' ,mean on evo's? F*cking Quick
is there a factory that make only ''FQ'' or is the same factory that make GSR's etc? I believe the FQ's were only built/available in Europe
what's the difference between the FQ's? Mostly just the power output, but IIRC the suspension, clutch, etc. are all beefier on the FQ400, and then a few aero bits.
is there any evo IX with non-aluminium roof? IIRC, the US VIII and IX GSR's had a steel roof.
^^ well theres your answer. FQ-400's come with a TD06-20G, as well as MOTEC M400 i believe for there computer. Other then that only a small differance between it and a stock IX (well for the money differance anyway).
Originally Posted by Wikipedia
Evolution VIII
Eighth generation 2005 Mitsubishi Lancer Evolution VIII MR (US Spec) at Deal's Gap, North Carolina
Production January 2003–March 2005
Platform CT9A
Transmission(s) 5-speed manual
6-speed manual
Wheelbase 2,625 mm (103.3 in)
Length 4,490–4,535 mm (176.8–178.5 in)
Width 1,770 mm (69.7 in)
Height 1,450 mm (57.1 in)
Curb weight 1,320–1,410 kg (2,910–3,109 lb)
The Evolution was modified again in 2003, this time sporting 17" grey Enkei wheels, Brembo Brakes and Bilstein shocks to handle traction and a 5-speed manual gearbox with 280 PS (271 hp/206 kW). Originally a one off model, sales were so successful in the U.S. that by 2005 it was available in four trims: the standard GSR model in Japan, the RS, with a steel roof, 5-speed gearbox, and standard wheels (lacking excess components, such as interior map lights, power windows/doors, and radio), the SSL (with a sunroof, trunk mounted subwoofer, and leather seats), and the MR, which came with a revised limited-slip front differential, aluminum MR shift knob, handbrake with carbon fiber handle, 17 inch BBS wheels, aluminum roof, and a 6-speed manual gearbox. The new Evolution also sported chrome housing tail lights.
The Lancer Evolution VIII MR uses slick-response Bilstein shocks for improved handling. The aluminium roof panel and other reductions in body weight have lowered the centre of gravity to produce more natural roll characteristics. Detail improvements have also been made to Mitsubishi’s own electronic all-wheel drive, to the ACD 5 + Super AYC 6 traction control, and to the Sports ABS systems. The Lancer Evolution VIII displayed at the 2003 Tokyo Motor Show took the MR designation traditionally reserved for Mitsubishi Motors high-performance models (first used for the Galant GTO). Other parts on the MR include BBS alloy wheels, the aforementioned Bilstein shocks, and an aluminium roof. In the United Kingdom, many special Evolutions were introduced, including the FQ300, FQ320, FQ340, and FQ400 variants. They came with 305, 325, 345, and 405 hp (227, 239, 254 and 298 kW), respectively.[4][5]
The FQ400, sold through Ralliart UK, produces 411 PS (302 kW; 405 hp) from its 2.0 L 4G63 engine, the result of special modifications by United Kingdom tuning firms Rampage Tuning, Owen Developments, and Flow Race Engines. At 202.9 hp (151.3 kW) per litre, it has one of the highest specific outputs per litre of any roadcar engine. With a curb weight of 1,450 kg (3,197 lb), it achieves 0-60 mph in 3.5 seconds, 0-100 mph in 9.1 seconds, 1/4 mile in 12.1 seconds at 118 mph (190 km/h), and a top speed of 175 mph (282 km/h) while costing £47,000. BBC's television series Top Gear demonstrated that the stock FQ-400 could surprisingly keep up with a Lamborghini Murciélago around a test track. The Stig recorded a Top Gear Power Lap Times of 1 minute and 24.8 seconds, 1.1 seconds slower than the Murciélago's time of 1 minute 23.7 seconds.[6] In a similar test conducted by Evo magazine, the Evolution was able to lap the Bedford Autodrome faster than an Audi RS4 and a Porsche 911 Carrera 4S.
The Lancer Evolution VIII was also the first Evolution to be sold in the United States,[7] spurred by the success of the Subaru Impreza WRX which had been released there just three years prior.[2] The Evolution VIII found its true competition in the Subaru Impreza WRX STI model the same year as the Evolution VIII's US introduction. However, the internal components for the American versions were largely stripped-down versions of the specifications for the Japanese Lancer Evolution VIII. No US-spec Evolution model prior to the Evo X has active yaw control, including the 2006 Evolution IX. The American 2003 and 2004 GSRs are without the helical limited-slip front differential and 6-speed manual transmission. The 2004 US spec RS models, however, do have a front helical limited-slip differential. All 2003, 2004 and 2005 RS and GSR models have the Japanese Evolution VII's 5-speed transmission. The MR edition was introduced to the US in 2005, with ACD and the only model with a 6-speed transmission. The 2005 US spec RS and GSR have the ACD standard, and the front helical limited-slip differential is now standard on all models. The boost, timing, and tuning are also significantly lower than its Japanese counterpart, allowing it to adhere to the strict emissions regulations of the United States. Starting in 2005, the US model Evos were also fitted with a 5000rpm limit on launching in 1st gear to protect the drivetrain.
Most Evolution VIIIs have a carbon fiber rear spoiler with matching body-color endplates. Furthermore, the US versions of the Lancer Evolution VIII 2003-2005 were given bulkier rear bumpers than their Japanese counterparts to accommodate US safety laws in the form of the metal rear crash bar. All Evos have lightweight aluminum front fenders and hoods. MR and RS editions have an aluminum roof. Additionally, MR Editions come equipped with a 6-speed transmission, Bilstein shocks, and factory optional BBS wheels.
The basic RS Edition does not come with power windows, locks, or mirrors, an audio system, rear wing, sound deading material, map lamps or an anti-lock braking system. All Evo VIII RS models sold in the US have an air conditioning system. Power windows, locks, and audio systems could be had in the RS model through the addition of the "Urban Jungle" comfort package.[8]
[edit] Evolution IX
Ninth generation Mitsubishi Lancer Evolution IX MR
Production March 2005–October 2007
Platform CT9A
6-speed manual
Length 4,490 mm (176.8 in)
Curb weight 1,310–1,490 kg (2,888–3,285 lb)
Mitsubishi introduced the Lancer Evolution IX in Japan on March 3, 2005,[9] and exhibited the car at the Geneva Motor Show for the European market the same day.[10] The North American markets saw the model exhibited at the New York International Auto Show the following month.[11] The 2.0 L 4G63 engine has MIVEC technology (variable valve timing), and a revised turbocharger design boosting official power output at the crankshaft to 291 PS (214 kW; 287 hp) and torque to 392 N·m (289 lb·ft).
The USDM Lancer Evolution IX models: standard (Grand Sport Rally or "GSR" in some markets), RS (Rally Sport), SE (Special Edition) and MR (Mitsubishi Racing) varied slightly in their performance capabilities. Subtleties unique to each model accounted for variations in acceleration, handling and top speed. The RS excluded features standard on the standard, SE and MR models (stereo system, power windows and locks, rear wiper, rear wing, trunk lining and sound insulation). The result is a weight savings of over 60 lb (27 kg)
Although the RS is the lightest of the group, the RS did not manage to outperform the standard IX and the MR around a road course (even if only by fractions of a second). This was purported to be due to the lack of a rear wing on the RS. In a drag race, the three models are all about even. The RS model was produced for rally and racing teams who wanted a platform to build a race car from. It is stripped of all the creature comforts, and other upgrades that drive the price up for features that the race teams would not require.
The IX MR retained the features of the Evolution VIII MR, like Bilstein shocks, a 6-speed manual transmission, a rooftop vortex generator, BBS forged wheels, HID xenon headlights, foglights, accessory gauge package, "zero lift" kit, special badging and an aluminum roof. All models continued to sport Recaro bucket seats, Brembo brakes and Momo steering wheels. Additional revisions from 2005 included a closer gear ratio for the 5-speed manual transmission, new lighter Enkei wheels on non-MR models, a redesigned front end with a more efficient air dam (the most noticeable feature are the two small oval ducts to cool the intercooler pipes), and a new rear bumper with a diffuser undersurface to smooth out the airflow coming out of the car for non-US models. In an effort to reduce the price increase on the Evolution IX model,[citation needed] HID headlights were no longer standard equipment on the base IX (nor were they standard on the 2005 VIII), and were available only in the SSL package (Sun, Sound, and Leather), SE (Special Edition) and MR trims.
Three trims were available for Japan, Asia and Europe. Although all models used the same 291 PS (214 kW; 287 hp) engine, the torque differed from one model to another. In Europe, however, the Evolution IX was advertised to have 280 PS (206 kW; 276 hp). The GSR produced 400 N·m (295 lb·ft) of torque, while the RS and GT produced 407 N·m (300 lb·ft).
* RS - "rally sport", revised 5-speed, aluminium roof, gauge pack, minimal interior, LSD and a titanium-magnesium turbine, left-hand drive option available.
* GT - revised 5-speed, this is basically the RS mechanically, but with some of the GSR's features (mainly interior pieces).
* GSR - 6-speed, Bilstein monotube shocks, aluminium roof, gauge pack, SAYC (Super Active Yaw Control), and double-din radio (this is roughly equivalent to the USDM MR).
In the United Kingdom, the Evolution IX used a different model scheme based on the car's horsepower. There were initially three models available: the FQ-300, FQ-320 and FQ-340 each with around 300(296/221), 320(316/236) and 340(336/250) PS(BHP/KW) respectively. An FQ-360 model was subsequently released as a successor to the Evolution VIII FQ-400. While the new FQ-360 produced less horsepower than its predecessor, it had more torque at 363 lb·ft (492 N·m) at 3200 rpm. All four models were designed to run on super unleaded petrol only. The MR FQ-360 was also released in limited numbers (only 200) in the last year of production.
* FQ-300, 320, 340 - 6-speed, Bilstein monotube shocks, AYC (Active Yaw Control), super unleaded petrol only
* FQ-360 - 6-speed, Bilstein monotube shocks, AYC (Active Yaw Control), Ralliart Sports Meter Kit, carbon front splitter, Speedline alloy wheels, super unleaded petrol only
* MR FQ-360 - New turbo with titanium aluminium alloy turbo fins, Speedline Turini alloy wheels, Privacy Glass, Lowered Eibach Coil springs (10mm at the front/ 5mm at the rear), IX MR interior, super unleaded petrol only
Four models were available in the US. All models used the same 286 hp (213 kW) engine.
* Standard - revised 5-speed, standard model
* RS - ralli sport, revised 5-speed, aluminum roof, gauge pack, minimal interior, also no radio
* SE - Special Edition, aluminum roof/hood, and front fenders, split seven-spoke forged aluminum BBS wheels in "diamond black" finish, HID headlights with integrated fog lights, red-stitched Recaro seats
* MR - 6-speed, Bilstein monotube shocks, split seven-spoke forged aluminum BBS wheels, aluminum roof, hood, and front fenders, gauge pack, HID headlights with integrated fog lights, vortex generator, and custom MR badging.
All of the American models are the same in power, but may differ in performance. The only thing that sets them apart is the Evo RS, which is 80 lb (36 kg) lighter than the MR and SE models.
To the standard model, the Sun, Sound and Leather package added a power sunroof, HID xenon headlamps with integrated fog lights, a slightly different stereo headunit (with no integral amplifier), slightly upgraded speakers in the front doors and parcel shelf, a 4.1-channel amplifier under the driver's seat, a powered, trunk-mounted Infinity subwoofer, black leather seating surfaces, leather-trimmed door panels, slightly revised center armrests in the front and rear, and separate rear side headrests. This model deleted the GSR's headliner-mounted sunglass holder to make room for the sunroof.
The Philippines had the Evolution IX until in August 2008, which was offered in two trims, the entry-level RS offering a 5-speed manual transmission, Brembo 17-in. ventilated discs (4-Pot), Brembo 16-in ventilated drum-in-disc (2-Pot) and almost the same features as to that of the GSR trim in the international version. Some RS models had the SAYC option, while some did not. The MR was the top-of-the-line segment, which offers almost the same feature as to that of the MR trim in the international verision. All of them are powered by a l4 2.0 4G63 turbocharged MIVEC engine.
Platform CT9A
6-speed manual
[edit] Evolution IX
Platform CT9A
6-speed manual
Its my first day on the internet
Lancer Evolution VIII MR FQ400 parts list:
Custom built Garrett GT Dual Ball bearing Turbocharger
Owen Developments custom manufactured cast Stainless Steel Exhaust Manifold and Exhaust Elbow
Omega Forged Pistons
HKS Forged Con Rods
HKS 680cc Injectors
Zytec ITP116 High Pressure Fuel Pump
HKS 1.6 mm Steel Head Gasket
Motec M800 OEM ECU
HKS Iridium Spark Plugs
Jan Speed High Flow Sports Cat
Alcon competition derived 240 mm high clamp mode, heavy duty clutch complete with Cera-metallic 6 paddle sprung centred drive plate
HKS High Strength Head and Big End Bolts
Alcon Mono6 Brake Kit incorporating Monobloc 6 pot road caliper with 343 mm curved vein Disc on a Aluminium mounting bell assembly with Ferodo DS2500 brake pads
Ralliart Aero Mirrors
Carbon Fibre Front Lip Spoiler
Carbon Fibre 'Sharks Tooth' Rear Vortex Generator
PIAA High Performance Light and Wiper Upgrade
Gloss Black Team Dynamics Lightweight Alloy Wheels
Driver Training Course
Now you know.
HKS Forged Con Rods
HKS 680cc Injectors
Motec M800 OEM ECU
Now you know.
Has anyone else read MLR's FQ400 report? It really wasn't that great of a car:
http://www.lancerregister.com/art_fq400report.php
