Buschur LICP to ETS 3.5" FMIC?
Old May 6, 2010 | 06:54 AM
RunThat's Avatar
Question Buschur LICP to ETS 3.5" FMIC?
I currently have the ETS 3.5" FMIC and LICP, however I would like to switch to the BR LICP if possible. Is this doable or would I need to do a bit of fabricating and/or cutting?
Old May 6, 2010 | 07:10 AM
JakeTheVIII's Avatar
Why? Switching from an ETS to a Buschur LICP isn't going to do much/anything.
I'm not sure if the Buschur piece still enters in the back of the fmic, but if that's the version you're talking about, it won't work without cutting and welding. The pipe enters the FMIC from a completely different angle than the ETS
Old May 6, 2010 | 07:17 AM
4RETECH's Avatar
Your ETS is near stock location on the FMIC. The Buschur LICP is for a Buschur FMIC which is a back tank entry ( not close to stock), so yes, fabbing will be required.
But when in doubt ask ETS or Buschur.
Old May 6, 2010 | 08:44 AM
ETS Michael's Avatar
I'm not sure if it's going to work. Why do you want to switch? We use a full 2.5" mandrel bent lower pipe, I don't think your going to notice anything unless your lower is damaged.
Thanks!
Michael
Old May 6, 2010 | 09:05 AM
RunThat's Avatar
Mike,
I was considering switching bcus I would like to use the FP race pipe with the FP Black turbo and I know that it really only mates up correctly with the Buschur LICP. If YOU have another solution, please lmk.
Old Apr 9, 2011 | 04:27 PM
drewdq's Avatar
I am in the same boat...I have an ETS 3.5 FMIC, and would like to use the FP race pipe with a Black turbo. RunThat, did you ever find a solution?
Dec 27, 2013 09:16 PM
80210
Apr 3, 2012 08:16 PM
metalmellinium
Northwest Region
Dec 15, 2008 02:56 PM
uglyevo
Northwest Region
Oct 1, 2008 07:22 PM
importjake00
ExtremeTurboSystems.com – WA
10
Aug 31, 2008 12:30 PM
