Compression Test today 100/120/117/118
Old May 7, 2010 | 09:12 AM
GG06MR's Avatar
Originally Posted by Enzo1089
So what are the major draw backs of having low compression, besides needing a motor overhaul...
Assuming your rings are toast in that cylinder, then you should be seeing oil consumption, and then a corresponding reduction in power.
I'm trying to stay positive and think that having my compression messed up is robbing my power so the car will be faster when its fixed This is correct right?
Yes, you're at least being robbed of power in that down cylinder, since the fuel that's being ignited is not all being used to force the piston back down, as some of it is certainly escaping around the poor ring seal.
The bigger question that needs to be answered is how the rings failed in that cylinder to begin with. Hopefully it's nothing major so you can have the shop do a simple hone job, fit it with some better rods and pistons, and then get back to having fun with it.
Old May 7, 2010 | 09:22 AM
rgeier11's Avatar
It could also be bad cam timing. Has you or someone else messed with the timing belt at all?
Old May 7, 2010 | 09:24 AM
GG06MR's Avatar
That would also affect all 4 cylinders instead of just one.
Old May 7, 2010 | 10:02 AM
Enzo1089's Avatar
The crappy thing is I just bought a new turbo, looks like that'll have to wait
Old May 7, 2010 | 10:03 AM
Enzo1089's Avatar
Originally Posted by GG06MR
Hopefully it's nothing major so you can have the shop do a simple hone job, fit it with some better rods and pistons.
How much does this usually cost in labor?
Old May 7, 2010 | 10:24 AM
GG06MR's Avatar
The charge to hone it is cheap, i.e. less than $100. It's all of the other stuff that adds up if you pay them to do it, like disassembling the block, balancing the crank to the lighter pistons, etc. So, the cost really depends on how much of it you can do yourself.
Old May 7, 2010 | 12:51 PM
rgeier11's Avatar
All the cylinders are low
Old May 7, 2010 | 12:58 PM
GG06MR's Avatar
Yes, but one is considerably lower(at least 15%) than the other 3. Cams, timing, etc. could all potentially lower the compression, but it wouldn't account for one cylinder being that far off from the other three.
Old May 7, 2010 | 01:06 PM
05blue8's Avatar
At an Evo shop you're looking at $750-$1500, seeing as your in Cali probably toss in an arm also
Old May 7, 2010 | 01:08 PM
GG06MR's Avatar
That sounds like a full bottom end rebuild, not including parts, correct?
Old May 7, 2010 | 02:28 PM
Wht03evo8's Avatar
Well since we are all on the thing of mystery!! I have a 03 Evo 8 with 56k miles and the Compression in cyl1-150 cyl2-170 cyl3-170 cyl4-170...
At 5500 rpm on the dyno just yesterday it gave 7 counts of knock!!!
HELP
Old May 7, 2010 | 08:16 PM
GG06MR's Avatar
HELP
Sounds like you need to wet test it.
Old May 7, 2010 | 09:21 PM
Gary@MellonRacing's Avatar
HELP
if i remeber correctly , ans someone correct me if im wrong , if u have lower compression on 1 cylinder , and u add oil and the compression goes up , then its the rings...
if u add the oil and the compression dosent go up at all then , problem with your valves
Old May 8, 2010 | 04:37 AM
GG06MR's Avatar
That's my understanding too.
Yes, either the valves or the HG.
Old May 8, 2010 | 10:08 AM
3gEclipseTurbo's Avatar
I have a friend that had weird compression numbers because his cams where off, and the were big 280's. Make sure your timing is correct. Also do that oil trick.
