h-beams and oem bearings handle big power?
Nitriding isn't a coating it's a heat treatment. Nitriding penetrates anywhere from .020 to .080" into the crank. Even if you took out all the nitrided steel when you grind the crank .010" over you could still have it nitrided again. And if you needed to take more out you can have the crank welded, reground, and nitrided.
Mitsubishi themselves say the cranks are not serviceable, and 99% of the time the cranks are cut and never re-nitrided. If you want to go through the work of welding grinding nitriding and balancing go right ahead but most shops won't tackle the job, it'll cost somewhat similar to a new crank and who knows if it's nearly as reliable as a new crank. I sure as hell don't want a welded crank..............
Yeah I was listing that as a last case scenario. If you cut .010'' off a crank you wont have to have it nitrided again. Mitsubishi wants to sell you cranks. I don't trust their opinion. There are cars running cut cranks that run just fine. I wouldn't do it on a 1000hp car, but for most it's fine.
I have NEVER seen a 10/10 crank last any appreciable amount of time in anything, if it needs cut you need a new crank.
To answer your question about bearings-
Torque not horsepower is the issue, 550 ft lbs (typically somewhere around 650-700whp) is the normal limit before steel rods regardless of brand or type start imparting damaging harmonics to the bearings. RPM is the next cause of issues and this seems to be anything over 9400. That being said we have a customer who on his steel rod motor was turning 94-9500 and went 10k on one set of bearings. They were not completely damaged when pulled, no noises we were just doing a check pre-season. The car is raced every chance he gets whether its on pump gas (580whp) or Q16 (40psi and 708+). It does not live an easy life but what can you expect when it runs 140+mph traps
For most it continues to spin bearings. If it cant be micro polished it destined to be a mailbox post or table leg. 10/10 cranks were cool 40 years ago when my Grampa started his shop building budget motors for circle track cars.
I'm searching now for a thread where a guy at a metal lab analyzed a cross section of our cranks and found nitriding to be more than sufficiently deep.
I'd say more often than not the crank grinder doesn't know what they're doing, and the customer didn't check it after.
That depends upon the H-beam rod in question.
Carrillo, Arrow, Wossner? - Yes.
Eagle, Manley, K1, Brian Crower, and similar rebranded Chinese rods? - Given the torque loads that typically accompany 600+whp, I wouldn't recommend it.
AFAIK, the factory crankshafts are induction hardened, not nitrided. Induction hardening is a surface treatment - not like nitriding. They should not be turned.
Don't equate the factory crankshaft to aftermarket nitrided billet cranks. The latter are salvageable.
What I can tell you is that a real 'race' bearing usually differs from OEM parts in several ways. For starters, race bearings typically have a harder backing that improves their structural rigidity. Also, race bearings typically have a harder surface material, which although less forgiving to dust and dirt in the oil (which OEMs must consider), is less likely to wear unusually under severe service. Likewise, race bearings are sometimes deliberately configured to channel oil more rapidly away from the edges of the bearing, which is just as important as is feeding oil to the bearing.
With a motor of only 4-cyl that is expected to bear such high torque loads, I am a believer in buying bearings best suited for the job (e.g. ACL Race, Clevite 77, etc.). I even have them sent off for an additional surface treatment before using them.
real fast
Apr 15, 2016 05:28 PM
real fast
Feb 9, 2016 06:59 PM
