Cam position sensor question
So Im trying to figure out my horrible misfire issue, Im coming to the conclusion that the CPS is bad. It misfires only in boost. I have tried 3 different sets of plugs and 2 seperate heat ranges (BPR8ES and BR9ES). Gaps I have tried were from .023 to .020 and nothing seems to work.
I pulled the sensor out last night and noticed that there was quite a bit of oil in the housing. Is this normal?
I do run something equivelant of a BR COP since it is wired the same. As well as a AEM EMS. When on the dyno on Saturday there was a misfire around 6200 and when I got the car home it progressively got a lot worse.
Is this typical of a faulty CPS? Mitsu, Autozone, and Advanced all have the sensor in stock but I just want a few other opinions.
Thanks in advance.
Thanks in advance.
I would try the stock coils and plug wires to see if it quits breaking up before you blame it on the ecu. What boost levels is it breaking up at? There should be oil in the Cam Sensor housing.
I do run something equivalent of a BR COP since it is wired the same. As well as a AEM EMS. When on the dyno on Saturday there was a misfire around 6200 and when I got the car home it progressively got a lot worse.
Thanks in advance.
Thanks in advance.
Up until 6200 all fine, then if i keep going it seems like it is hesitating until redline (obvious lack of power) and then after that it runs on 3 cylinders for 2-10secs until it clears up...
My car is an evo 9 with oem turbo and tune on the OEM ecu (speed density).
Did you find what was the problem? I am at a dead end at the moment as i checked pretty much everything and any help would be much appreciated at the moment!!
Thank you in advance
TLeid91
Apr 4, 2016 07:43 AM
