First gear shift Thud
Old Nov 11, 2003 | 11:51 PM
n00dle's Avatar
hey guys thought I'd mention it cause I *had* similar problems like those posted here ie; grinds and difficulty shifting no matter how carefully I tried to coax it. My car currently has 2,000 miles on it. The first 800 were fine with no problems. Shortly thereafter the symptoms began to appear, it didn't matter weather it was cold or hot, but it was a tad smoother when hot. So next thing to do was drop the fluids which I planned on doing just not so soon. What I found was that only 2 quarts were in the tranny. That's 1 quart too low and most likely contributed to the symptoms. I also checked the transfer case and rear diff by removing the fill plug to see how full they were. What I found was that they weren't completely topped off, which was verified once I drained them out. They were not alarmingly low like the tranny, but low nevertheless. Anyhow, I replaced them with Redline fluids and all is good now. I'm sure Redline probably contributes to the smoother action, but having low fluid levels to begin with was probably a major contributor to the problems. I'm just glad I caught it early on. Those that have not changed out the factory fluids yet many at least want to check to see if they're topped off at the fill plugs.
simevo's Avatar
Get the tranny fluid changed to a 75W-90 synthetic. It helps alot even going into 2nd at higher revs.
Old Nov 12, 2003 | 10:27 AM
boostedwrx's Avatar
BG Sychroshift II performed TONS better than Redline 75w90 for me. I have the redline in now, and my second gear synchro sucks *****. I need to put BG Synchro II back in..
mullski
Jan 10, 2011 10:07 AM
EVOLV3D
Mar 20, 2009 08:22 AM
evo8drifter
20
Mar 30, 2007 02:31 PM
zstryder
28
Aug 15, 2005 09:19 AM
Rahzek
Mar 26, 2005 11:49 AM
