Kiggly HLA Pressure regulator, worth doing?
Old May 13, 2010 | 03:00 PM
Erik@MIL.SPEC's Avatar
This thread is full of win. Can I say that as a vendor?
Old May 13, 2010 | 03:03 PM
Philthy748's Avatar
Old May 13, 2010 | 10:05 PM
1slowlaser's Avatar
If a part is being sold to the public by Kiggly, you can bet your *** it wont let you down. That goes for anything he sells.
Old May 13, 2010 | 10:21 PM
RSMike's Avatar
i put my order in today through Chris @ Maperformance
Old May 13, 2010 | 10:39 PM
project_skyline's Avatar
Great information in here. I'll be getting this on my engine build without a doubt.
Old May 14, 2010 | 11:36 AM
Ted B's Avatar
I installed one during my last refresh. Drifto and I both use one.
As for how much oil pressure at the lifter is required to maintain accurate valvetrain action, that is another question, the answer which would likely vary from setup to setup.
Old Jun 1, 2010 | 02:30 PM
kiggly's Avatar
Just to clarify, the oil pressure is only reduced to the lifters. The cams and turbo feed stay at full pressure.
Kevin
Old Jun 1, 2010 | 02:51 PM
RSMike's Avatar
Kevin
Thanks for the input Kevin,
Does this item by design also "restrict" oil to the head? I.e. oil isn't "wasted" by being in the head where it isn't needed, except for the cams and HLA's?
Or will my engine builder still need to look at running a restrictor?
Cheers, Mike
Old Jun 1, 2010 | 03:11 PM
03whitegsr's Avatar
Are the spring cooling jets on the cam feeds or the lash adjuster feeds?
Also, any real world feedback on how much this helps with valvetrain noise. I get a lot of lifter tick with these FP 280+ cams.
Old Jun 1, 2010 | 03:18 PM
EmeryatSTM's Avatar
Just ordered mine! Now I may be able to stop filling catch cans at the end of the track! lol
-Em
Old Jun 2, 2010 | 09:53 AM
crewdawg130's Avatar
+1 ^^^^^^^^
Old Jun 2, 2010 | 10:05 AM
Ted B's Avatar
I've not noticed any change in valvetrain noise, but I have observed less oil misting under the cam cover and less accumulation in the catch cans.
Old Jun 2, 2010 | 10:08 AM
nyquil2's Avatar
Any install pics?
Old Jun 2, 2010 | 10:19 AM
Ted B's Avatar
They really aren't necessary. If you know how to remove the cam cover, you'll see the factory oil feed cover it replaces. It takes about 60 seconds (3 screws) to replace it with Kiggly's part.
Old Jun 2, 2010 | 11:28 AM
nyquil2's Avatar
so all the factory pieces are used with it?
I.E. 3 screws, lines?
