timing belt tensioner ruined?
Old May 15, 2010 | 06:48 PM
kaj's Avatar
kaj
Originally Posted by nightwalker
^ Have you ever done a timing belt before?
not on an evo, nope. i've never seen an engine where it mattered if an oil pump skipped a tooth. i've never seen one that had to be "timed" with the other pulleys.
i didn't see anything on any how-tos about making sure the oil pump was lined up with everything else.
that is just silly. LOL
pulling the timing covers off now. i'll see what's up.
**edit. just re-read the service manual. found where to line up oil pump. i'm on it.
Old May 15, 2010 | 07:36 PM
jmelocik's Avatar
Factory Service Manual FTW!!!
Josh
Old May 15, 2010 | 07:47 PM
kaj's Avatar
kaj
Josh
you know it, brotha! wouldn't leave home without it. following OEM guidelines for putting this bad boy back together. so far, so good. will report back
Old May 16, 2010 | 12:00 AM
turbotalawd's Avatar
the only reason why you have to line up the oil pump is because of the balance shafts.
Old May 16, 2010 | 12:34 AM
kaj's Avatar
kaj
noted. i pulled the timing cover off. oil pump is lined up. crank is lined up. timing belt looks REALLY nice, but @ 57k miles, may as well replace it.
now.. as long as i didn't bend any valves, i'm good to go. man. i hope i didn't bend any valves.
i'll post updates as i find them.
Old May 16, 2010 | 02:23 PM
nightwalker's Avatar
if you jumped three tooth, you may have.
If you worked on other import engines (Hondas and Toyotas) You can't use the same methods for the 4G63.
The Evo timing belt should be replaced every 60k anyways.
Old May 16, 2010 | 02:38 PM
kaj's Avatar
kaj
Pretty much what I'm thinking. Especially with a 272 duration and 11mm lift. :-( but I'm remaining hopefull.
Boy, am I finding THAT out. The hard way.
Yup. Ordering a new one today. Especially seeing how I'll be tracking the car.
Hotsauce101
Apr 6, 2016 06:27 PM
stefenboy
Dec 9, 2015 03:20 PM
pettyboy69
Mar 27, 2011 07:56 PM
kaj
Jul 4, 2010 01:54 PM
scottatyamaha
17
Mar 20, 2010 10:27 PM
