Safe A/F ratio for dynotune?
Old Nov 12, 2003 | 07:42 PM
zstryder's Avatar
So I'm getting my car dynotuned with a wb02 in about two weeks - I was wondering what a safe ratio would be?
Mods:
HKS DP
JIC catback
GReddy ProfecB SpecII EBC
SAFCII
I've kinda tuned the EBC myself but I'll have them take a look to double check it, and I'm using a fairly conservative baseline SAFCII tune.
I was thinking of shooting for ~11.0, would it be wise to lean it out any further than that? Also, for those that have gotten their SAFC's tuned, are there any dips/peaks typica of the Evo powerband that I should be aware of just to make the tuning job easier?
Old Nov 12, 2003 | 07:45 PM
DynoFlash's Avatar
Re: Safe A/F ratio for dynotune?
Mods:
HKS DP
JIC catback
SAFCII
IMHO 11.0 i a very good point
I run my car at that level
You CAN mak a bit more power leaner - BUT on the stock ecu the knock sensor will start to pick up come noise and pull timing effectively negating that extra power
Some other tuners de-sensitize the knock sensor to get around this - which results in very severe engine wear and a shorter enine life span - detonation - no matter how slight is very destructive
Old Nov 12, 2003 | 07:47 PM
zstryder's Avatar
Thanks Al!
I was wondering, on a typical dynotune, do they monitor knock while tuning? Or ignition timing etc.? Otherwise, just making sure the A/F ratios are safe may not necessarily get the best tune...
Old Nov 12, 2003 | 07:54 PM
boostedwrx's Avatar
Al youve said you run 10:1 bla bla
Zstryder-
You need something to monitor your ignition advance from your OBDII port. This way you can SEE where you are getting knock by viewing where your timing dips. Theres nothing out yet to monitor knock on the EVO, as there is for the 1G DSM. The easiest thing to buy is a datalogger or a pocket logger peticularly (www.pocketlogger.com) to view your timing advance.
With a good AFR tune and something to see your timing, you can get a very good tune. When your timing drops, give er a splash of fuel with your SAFC, and tune on man!
FYI I run at 11.5 AFR even at 21psi. Why? Because the stock ecu advances timing 21 degrees close to redline. I could even afford to up the boost a tad.
Old Nov 12, 2003 | 07:58 PM
boostedwrx's Avatar
Re: Re: Safe A/F ratio for dynotune?
We ALL know where that was going hehe.
Old Nov 12, 2003 | 08:06 PM
DynoFlash's Avatar
Zstryder-
BLA BLA yourself - your ignorance is really beyond my comprehension !
There are many universal knock meters available which will work on any car
Old Nov 12, 2003 | 09:40 PM
boostedwrx's Avatar
like....??? Besides standalones????????????? ............ ??
Old Nov 12, 2003 | 09:45 PM
boostedwrx's Avatar
Old Nov 12, 2003 | 09:49 PM
DynoFlash's Avatar
Try the Knock Link which you can get from vivid racing and which uses a bosch knock sensor - the whole set up is around the low 200's
Old Nov 13, 2003 | 08:43 PM
zstryder's Avatar
I don't have the funds right now to shell out for a pocketlogger or a knock sensor, do you think they would dynotune with some sort of knock sensor? It only makes sense, right?
Old Nov 13, 2003 | 08:52 PM
DynoFlash's Avatar
You would be surprized ! I have seen some crazy dyno stuff !
Where are you going ?
Old Nov 13, 2003 | 08:55 PM
zstryder's Avatar
I'm going to Agile Automotive - the place you're going to reflash a bunch of the DCEvo club guys. I was actually gonna show up the same day to check out the reflash action but Agile couldn't fit me in on saturday, so instead I'm heading up there on the 26th.
I emailed Hill to ask about the knock/ignition logging, but he hasn't gotten back to me yet..
Old Nov 14, 2003 | 07:05 AM
boostedwrx's Avatar
they wont have jack. Youll be lucky if they can log AFR based on RPM..
Old Nov 14, 2003 | 08:05 AM
zstryder's Avatar
They said they had a wb02. Have you had experience with them?
Old Nov 14, 2003 | 08:10 AM
boostedwrx's Avatar
with widebands, yes. You need an Aux input to tap into your RPMs in order to log your RPMs and AFR. I dont know how dyno shops do it like Pruven or anyone. I always see these dyno charts with HP/Torque/RPM/AFR. So you might want to ask DynoNeezy.
I have an LM-1 Wideband and am still waiting on their aux input to log RPMs also. Right now im still playing the guessing game... oh yea it looks like its a little lean here..
