Need help diagnosing problem, bogging
Old May 22, 2010 | 02:08 PM
DSMpsi's Avatar
2003 VIII, 100% stock, 60k miles
My friend is having trouble while at 1/2 throttle to WOT. The car seems to buck or bog down when hitting about 12lbs of boost. It starts bucking from 4-6k and sometimes clears up by redline. He thought it had to do with the ignition system so he decided to replace everything. Coils, plugs, wires, CAS, clean the MAF, etc. His boost seems to be topping out around 14-16 psi.
Anyways, I think it has something to do with fuel, to me, it feels like fuel cut, when there is too much boost and not enough fuel. I was thinking possibly the regulator or the pump, but Im just guessing off the top of my head. I haven't tested the fuel pressure for him yet, but will be doing it Monday. FYI, there are no CEL's at all.
I was just wondering any input you guys have to help us out.
Thanks
Old May 22, 2010 | 03:55 PM
3gEclipseTurbo's Avatar
needs to be tuned
Old May 22, 2010 | 05:20 PM
DSMpsi's Avatar
Great, thanks for all the help...
The car is stock and will be staying stock. Plus the car would need to be fixed before it would ever get tuned.
Old May 22, 2010 | 05:27 PM
max4rw's Avatar
boost leak. do a test I bet thats the problem
Old May 22, 2010 | 05:38 PM
sho669's Avatar
+1 beat me to it
Old May 22, 2010 | 06:40 PM
gsrboi80's Avatar
+2 thats my guess for sure
Old May 22, 2010 | 06:51 PM
DSMpsi's Avatar
Lol, thanks guys but I did it already too. I pressurized it up to 25psi and it held fine.
Any other suggestions?
Old May 22, 2010 | 10:44 PM
The problem it tune related, the bogging is knock and the ecu pulling timing. If it was fuel it wouldnt go away after 6k it would get worse. Its easy to see if thats it log the car.
Old May 24, 2010 | 06:18 AM
DSMpsi's Avatar
How would it be tune related? The car is 100% stock with no aftermarket tune. There is no knock, plus the car would be pulling a DTC if any of that would be happening. Theres no point in tuning the car when it was fine last week, you dont just randomly tune cars to hide the problems your having. You have to fix the current problems at hand then modify or tune it.
It usually bucks till red line, but sometimes its only from 4-6k.
Old May 24, 2010 | 06:53 AM
Steve93Talon's Avatar
Log it.
Old May 24, 2010 | 08:17 AM
sktng22's Avatar
Whens the last time u changed ur oil. my car was doing this after not changing my oil for 10k miles. i changed it the other day and all of a sudden theres no lifter tick or bog anymore! lol
Old May 24, 2010 | 08:54 AM
DSMpsi's Avatar
He changed his oil 1k ago. I feel sorry for your car, 10k miles between oil changes... wow.
Old May 24, 2010 | 02:49 PM
sktng22's Avatar
well i kinda want my motor to blow so it gives me a reason to take it apart and put these parts inside of it !!
