What fluid for the ACD
Old May 24, 2010 | 09:52 AM
dambikeracer's Avatar
Looking at changing the fluid in the ACD, what fluid do I use? I found something saying Mitshbishi Automatic Transmission Fluid, is that right? And should it be changed each time I change the fluid in the t-case?
Old May 24, 2010 | 10:11 AM
PATRICK B.'s Avatar
Yes that's what i use Mitsu ATF.
I don't replace it everytime i have the TC fluid out but i change it more frequently than most.
Old May 24, 2010 | 10:13 AM
Ryuartz's Avatar
I used Mobil ATF
Old May 24, 2010 | 05:39 PM
How often should the ACD be changed? I do the tranny, t-case and rear diff every 10k.
Old May 24, 2010 | 06:33 PM
wasabisnooter's Avatar
subbing
Old May 24, 2010 | 06:34 PM
wizzo 8's Avatar
I used normal ATF
Old May 25, 2010 | 07:03 PM
bmxer4it's Avatar
Get the mitsubishi stuff. By far the best. and best for your car. change fluid whenever you do tranny. no need to do it more.
Old May 25, 2010 | 07:18 PM
irishone337's Avatar
You shouldn't use regular dextron/mercon ATF. But you can get any brand ATF+3 at any auto parts store. It's the same as the Mitsu stuff.
Old May 25, 2010 | 09:58 PM
Spoolin4g63's Avatar
Mitsu ATF
Old May 25, 2010 | 10:12 PM
Should I do it every 10K miles? Or not that often?
A3188
13
Apr 14, 2014 04:32 PM
yenny
Aug 23, 2012 08:03 PM
heingtaing
15
Mar 4, 2011 09:12 PM
Svendiesel
Jan 4, 2010 07:58 AM
r32gtr94
Jun 5, 2008 11:21 PM
