Turbo oil return line leaking
Old Jun 16, 2010 | 09:38 AM
19DB794's Avatar
Ttt for some more answers.
Old Jun 16, 2010 | 01:30 PM
project_skyline's Avatar
Originally Posted by 19DB794
Alright, thanks for the help. Are you 100% positive on that?
Yes. The flange should be machined flat and since the oil pan can have slight surface variations to it you want the raised part facing the pan.
I have also used the paper gasket for both the turbo side and oil pan side. I haven't leaked a drop since day 1.
Old Jun 16, 2010 | 02:02 PM
19DB794's Avatar
Alright, sounds good. I had to replace the oil line since there was pin sized hole on it but I never replaced the gaskets which seem to be leaking now. Do you remember which way you installed the paper gasket? Im just assuming the circle around the drain should be facing down towards the return tube.
Old Jun 16, 2010 | 09:06 PM
sparky's Avatar
Yeah, with respect to the paper gasket, the side with the outlined circle faces downward. I saw the factory flyer on this particular detail.
Old Jun 17, 2010 | 01:26 PM
19DB794's Avatar
Alright, sounds good. Thank you for all the help! I just need a break in the weather now so I can do it all.
Old Jun 21, 2010 | 01:46 PM
19DB794's Avatar
I ended up replacing the gaskets on Saturday and from the looks of it, the rubber washer/gaskets were the issue. The rubber was torn up so I replaced the bolts, gaskets, and rubber washers/gaskets on the oil pan and turbo side and it doesn't seem to be leaking now. I let the car run for a bit while it was up in the air and it didn't seem to leak at all. I'll have to keep and eye on it just to be sure but I hope its good to go. I just wanna thank everyone for the help!
Old Jun 22, 2010 | 06:23 PM
gohdunlam's Avatar
where can i get this?
Old Jun 22, 2010 | 10:31 PM
sparky's Avatar
Have your friendly parts guy at the dealership print you the exploded view of the page where all the turbo to drainpipe gaskets, washers and bolts, etc. are represented on his parts computer. This will give you a better idea of what bits you will need to order and how it goes back together upon assembly. The whole shebang will probably cost no more than $12-$15.
Old Aug 30, 2010 | 06:40 AM
JakeTheVIII's Avatar
Anyone know the part number for the special gasket washers for the return tube bolts (where it bolts to the oil pan)? I'm gonna call mitsu today and try to find out.
Actually just found it. Post # 2571 on this page: https://www.evolutionm.net/forums/ev...-here-172.html
The part number for the washer seal things are MR497720
Old Sep 4, 2010 | 07:33 PM
gohdunlam's Avatar
Thanks for all the help. I just ordered new gaskets for the turbo and oil pan side as well as the bolts and washers. Hopefully it wont be a pain to remove the bolts from the turbo side.
is there any washers or seals on the bolts that go into the oil pan?
Old Sep 4, 2010 | 07:54 PM
Genesis8's Avatar
When I took mine off, there was some sort of sealant on the bolts that goes on the oil pan.
Old Sep 5, 2010 | 02:49 PM
19DB794's Avatar
The part number is MR497720. They're just washers that have a rubber seal on them.
Old Aug 15, 2013 | 07:17 PM
tstkl's Avatar
I know this is "bringing a thread back from the dead" but for people like me who are searching for the answer to this question and cannot find it, I busted out my old Mitsubishi part number computer and found this:
File Type: pdf
EvoIX89
17
Sep 22, 2015 07:11 AM
NeveReveN
Jul 30, 2014 04:15 PM
scout113
Mar 13, 2014 09:07 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
26
Jul 3, 2010 05:56 PM
livelyjay
Lancer How Tos / Installations
Jul 24, 2005 02:26 PM
