Fuel line upgrade
Old Jun 10, 2010 | 03:19 AM
CNano8's Avatar
Fuel line upgrade
Im planning to run e85 on my 6262 setup at about 40psi (might go a little bigger later) but I have some questions about fueling. I have a Full Blown double pumper and planning on getting FIC 2150's and a aeromotive or buschur fuel rail. I know your only as strong as your weakest link and I was thinking about the lines. I think I read that the stock lines flow enough for about 700whp but thats on 93/116 with e85 you need 3x more fuel for the same instance. Is that fueling setup fine or should I upgrade to AN lines and if so what size? Thanks
Old Jun 10, 2010 | 05:16 AM
RunThat's Avatar
Others may want to elaborate on this, but from all my discussions with Full-Blown and others, it seems that a -10AN feed and a -6AN return line is more than sufficient for most setups like yours.
Old Jun 10, 2010 | 06:25 AM
Ted B's Avatar
Small lines increase frictional losses that can reduce pump capacity by at least a nominal margin. For E85, an AN-6 feed and return is a better proposition than the factory lines, and an AN-8 feed with AN-6 return is better still.
Old Jun 10, 2010 | 06:50 AM
CNano8's Avatar
Ok, thanks guy much appreciated.
Old Jun 10, 2010 | 08:12 AM
Celica2EVO's Avatar
stock lines are fine. Im running a Buschur Double pumper, Buschur fuel rail, ID2000s and stock regulator and Im at 708 on Buschurs dyno. Im on a HTA 86 which is a little bigger than the 6262 on im running about 43 pounds. So theirs really no need to spend the money for new lines.
Old Jun 10, 2010 | 11:27 AM
CNano8's Avatar
e85 correct?
Old Jun 10, 2010 | 01:43 PM
Celica2EVO's Avatar
E85 and I might be going to E98. My setup will support straight alcohol if I wanted to go that far.
Old Jun 10, 2010 | 02:06 PM
CNano8's Avatar
Ok good info. I think ill put that money, which is needed, elsewhere and ill cross that bridge if I need to I guess lol. Thanks
Old Jun 10, 2010 | 02:45 PM
Celica2EVO's Avatar
yea you should be fine. My only recomendation is go with the ID2000s instead of the FICs. The way the IDs run are phenomenal and well worth the money. If you need any help just let me know and ill help you as much as i can.
Old Jun 10, 2010 | 02:52 PM
RockmanX's Avatar
sup hommie long time no talk
Old Jun 10, 2010 | 03:26 PM
Celica2EVO's Avatar
very long time. lol how you been?
Old Jun 10, 2010 | 03:51 PM
RockmanX's Avatar
im doing great check out my build thread in show and shine buddy and comment on progress thanks
Old Jun 11, 2010 | 08:16 AM
SmurfZilla's Avatar
30% more is what you meant right?
anthonyrb98
31
Oct 31, 2012 02:34 PM
ilikeppie
10
Feb 21, 2011 06:24 PM
evoyrrah
Sep 19, 2010 09:01 AM
JDM_CEDIA
Lancer Engine Tech
May 10, 2010 06:56 PM
M4Lki3r
E85 / Ethanol
Apr 16, 2009 10:07 PM
