Mobil 1 oil filter
Old Nov 15, 2003 | 10:12 AM
RonV's Avatar
Question Mobil 1 oil filter
Is any one using these yet? They are smaller in diameter than the stock filter.
Any Input would be appreciated.......
Thanks
Old Nov 15, 2003 | 10:36 AM
1QWKEVO's Avatar
in most cases it won't be the same diameter, it would be smaller. I'd stick with the stock filter it's internal design is great for filtration.
Old Nov 15, 2003 | 10:42 AM
Jonasan50's Avatar
For this engine, stay with the factory filter.. It's your best bet...
Old Nov 15, 2003 | 10:44 AM
Quickshift's Avatar
I totally agree , stock is very well made. dont forget the crush washers after oil change.
Old Nov 15, 2003 | 10:54 AM
RonV's Avatar
Thanks for the responses guys. I was just curious to see if any has actually used the M-1 filter yet.
Old Nov 15, 2003 | 01:16 PM
1QWKEVO's Avatar
i've used them on previous cars, after cutting both filters open I noticed they are almost identical as far as their structure. As far as filtering several tests would have to be ran... Both use metal ends on the filter where cheaper filters like fram & etc use cardboard. Both have flow valves to keep fluid in the filter during startups and both use massive pleets (high number of pleets)
Old Nov 15, 2003 | 01:22 PM
Evilution VIII's Avatar
I used a Mobil-1 filter on my evo when my dealer was out of filters. nice filter i guess. but not sure if i would buy another one for the 12.75 i paid for it.
Old Nov 15, 2003 | 07:05 PM
sophis's Avatar
Been using the M1-110 the past 3 oil changes.
Old Nov 15, 2003 | 08:00 PM
RonV's Avatar
Hey Sophis,
how did you end up with the M-110? I bought mine form Mobile 1 online and they sent me 2 M-108's. It's allot smaller than the stock filter but they swear it's the right filter. I even called their hot line and they had me call Champion Labortories(the maker of the M-1 filters) and even they say I have the correct filter. Now I'm really confused!
Old Nov 16, 2003 | 11:14 AM
RonV's Avatar
Bump
Old Apr 12, 2006 | 05:51 PM
MyCre8n=Evlshn's Avatar
Registered User
The M1-108 is the "correct" filter for the Evo. It is smaller but the filter is superior to the stock ones....especially since the stock ones which are sold at the dealerships now are inferior to the original ones which came on our Evos. (do a search...I researched this topic at length a long time ago and there were some posts of people actually cutting apart the filters and comparing, etc). The Mobil 1 filters are probably a lot better than other brands and almost certainly better than the "stock" (whatever that means since the change) Mitsubishi filters.
In light of this, I was going with the M1-108 but then noted that someone was going with the M1-110, which is just a taller version of the 108. Now I'm going with the 110 because I figure there's more filter there so it should be a good thing. It's the same diameter, just slightly taller...so I think it'd be a better choice.
Old Apr 12, 2006 | 06:08 PM
cij911's Avatar
System 1
Have any of you considered using a System 1 oil flitration system onj the EVO? We used them on 911 race cars and they worked really well. A separate canister that you can open up and assess bearing et al wear during pits....
You may want to consider this option over a $12 Mobil 1 filter.....
Old Apr 12, 2006 | 08:35 PM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
where can I find more info on that ?
Old Apr 12, 2006 | 08:36 PM
sleet's Avatar
I just use the stock filter, no problems yet.
Old Apr 13, 2006 | 06:31 AM
LA EVO 8's Avatar
The last 5 oil changes I 've used the M1-110 so far no issues.
