Can I adjust clutch pedal/feel on Evo VIII?
Old May 22, 2012 | 04:38 AM
Pirana's Avatar
You guys just need a new clutch. Plate could be worn down and not fully disengaging.
Old May 23, 2012 | 07:10 AM
SinisterEvoVIII's Avatar
Problem Solved.... Adjusted My Clutch Pedal And My Car Shifts Alot Better.... Even During Cold Starts..... "Plus I Got Amsoil In The Tranny Making Every Shift Smooth"
Thanks For The Advice
Old May 23, 2012 | 08:35 AM
Pirana's Avatar
Good to hear!
Old Aug 20, 2012 | 10:37 PM
elim0's Avatar
Originally Posted by sna08
I had to adjust mines way up high when I got a new clutch put in. I was having real bad problems shifting into any gear at a stop. It had to roll for me to shift it easier otherwise I'm jamming it in. This adjustment really helped. After testing it down and up again seems to help at the highest engagement point which kinda sucks. I read somewhere that removing the pill will lower it a bit? Anybody know if this is true?
i know this is an old thread. but i recently did my new clutch and have been getting lockout at high rpms.. will adjusting it higher help the problem? is there anyway you can keep the engagement down without it locking out ??
Old Aug 20, 2012 | 11:36 PM
jrblackSE's Avatar
I know there is some minimal adjustment in the clutch. but I would recommend getting a new clutch and sending your trans off the SHEP and getting it refreshed! You shouldn't have a problem for the life of the trans from there! They do some amazing work! Best of Luck
Old Aug 21, 2012 | 06:27 AM
elim0's Avatar
my clutch is only 2months old (exedy stage 1 sports organic)
Old Aug 21, 2012 | 06:50 AM
wickedwyte06's Avatar
i agree my clutch is also very new, i have 4,000miles on my exedy stage 2, it grabs high which i like due to a lot of traffic driving, but if im in it and try to snag second gear it just wants to grind, also at a stand still going into reverse it just doesnt want to go unless i forcefully push it HARD to the right and then down? syncs going bad? if so do they have after market ones that are good? please forgive me i dont know much about a manual trans, i can build the hell outta a 4r100 though haha
Old Sep 24, 2012 | 02:47 PM
luvboost's Avatar
good info on here.
Uscbryan
Jun 7, 2014 08:46 PM
Shastamiknasta
Dec 9, 2012 07:13 PM
EvoDan2004
56
Aug 4, 2012 09:24 AM
JEP
May 13, 2011 05:55 PM
ambystom01
Lancer Tranny/Drivetrain Tech
11
Apr 21, 2010 03:34 PM
