TPS Adjustment Specifications
Old Apr 15, 2018 | 12:05 PM
2rbolag's Avatar
Originally Posted by Ted B
In that case, with the engine off, put someone else into the driver's seat and adjust the cable such that at full throttle, the metal tang that rotates with the shaft just contacts the throttle stop. That will do it.
excuse the thread revival but I don’t have evoscan and also dealing with a similar issue. Can you elaborate further on this process?
thanks
Old Apr 15, 2018 | 12:13 PM
Ted B's Avatar
Without Evoscan, with key on and engine off, you would need to measure the voltage at the TPS signal wire and adjust the TPS until you see ~0.7V closed and 5.0V at WOT.
thanks
Old Apr 15, 2018 | 01:22 PM
2rbolag's Avatar
thank you very much, can you confirm if green is the signal wire?
thanks again
kamote2000
May 9, 2015 03:55 AM
black_beauty
Feb 2, 2014 10:32 AM
awdordie
Aug 29, 2013 05:43 AM
sleepy_rps13
Feb 22, 2010 01:37 AM
idriveanevo
Apr 22, 2007 08:40 PM
