DTC P0106: Barometric Pressure Circuit Range/Performance Pro
Old Jun 25, 2010 | 05:16 PM
evo9nuuub's Avatar
keep getting a p106 code, i've changed the map sensor according to alldata.com but the code came back after a week, now i'm thinking about trying to test voltage for the tps.. when i first start it up in the mornings it surges up and down until it gets warm, its also running lean more than just at startup. i even stall sometimes while slowing down at stoplights and fourways..
Has ANYONE had this problem?
Old Jun 26, 2010 | 07:56 PM
evo9nuuub's Avatar
bump for any ideas
Old Jun 26, 2010 | 09:38 PM
mysticj's Avatar
MAS..check the baro signal and readings. If out of spec, replace MAS.
Old Jun 27, 2010 | 12:55 PM
evo9nuuub's Avatar
yea i've been checking voltage readings, everything seems okay but i have yet to check the mas air sensor, i'm going to look at that and see whats up.. it seems to run lean consistantly around 3k while cruising in any gear
Old Jun 28, 2010 | 10:09 AM
20gmr's Avatar
did you buy the car new? any chance someone put a different map sensor on it and it was calibrated for it in the ecu?
Old Jun 28, 2010 | 02:00 PM
evo9nuuub's Avatar
No, i bought it used from a guy in orlando. it had the original stock map sensor and i replaced it with another oem map sensor but the code came back two weeks later
JKX
Jul 28, 2016 01:01 PM
ThugzNHarmony
Jan 14, 2013 09:40 AM
Nega
Jun 25, 2012 07:15 AM
dahuii77
Oct 7, 2011 12:21 PM
8-BallEvo
Aug 3, 2010 07:55 PM
