Loud Bang, -10 to 15 PSI. Help needed
Old Jul 6, 2010 | 07:48 AM
nyquil2's Avatar
open the motor and take a look
Old Jul 6, 2010 | 08:07 AM
Sim2k's Avatar
Bump. I'm interested to know what the problem is, when you find it.
Old Jul 6, 2010 | 02:25 PM
godnf8's Avatar
I'm new to turbo's, but why would the motor have anything to do with the boost pressure? Bad turbo ok, bad wastegate, ok, bad lines, ok, motor ? You'd think if there was a motor issue then it would start differently, maybe idle differently, definately drive differently, in this case had you taken the time to read all the information I took time to provide as thoroughly as possible, that the car is just missing boost and drives perfectly fine. As I said though, I'm new to turbos, I'm sure I'm wrong about a lot of stuff, but if you could provide some reasoning behind this statement I'd be grateful.
Old Jul 6, 2010 | 03:08 PM
srcevo8's Avatar
I read that "open the motor" post to be sarcastic.
A few guys in this thread had similar experiences...might be worth skimming.
https://www.evolutionm.net/forums/en...-lines-ok.html
One solution on page 4 was simply replacing plugs.
Old Jul 6, 2010 | 03:16 PM
BoostFTW05's Avatar
you could be blowing out your spark tried gapping them any tighter?
Old Jul 6, 2010 | 07:03 PM
godnf8's Avatar
thanks for the link src, gave me a few ideas for troubleshooting the issue.
Old Sep 12, 2010 | 05:15 AM
godnf8's Avatar
This problem has been fixed. The end culprit was the MBC. Debris had apparently gotten inside some how causing it to quit working properly.
Old Sep 12, 2010 | 06:11 AM
bbyevo8u's Avatar
so what did you do clean it out? was the ball real dirty?
Old Sep 12, 2010 | 06:51 AM
rburris28's Avatar
I keep seeing this thought in multiple threads: that closing the gap will keep the spark from "blowing out".
However, the wider the spark gap, the higher the voltage required to jump it; therefore, the wider the gap, the hotter the spark, and the less likely it is to be "blown out". In fact, the NA series Miata engines make the spark jump the gap of TWO plugs before they fire, in order to increase the voltage across the gap.
At higher cylinder pressures there is a complicated interplay of tendency for the fuel to detonate vs. higher voltage required for the spark to jump the gap. In some cases, decreasing the gap may help; in others, increasing it may be the way to go.
I am sure that the experienced shops and racers have figured out the sweet spot for their plug gaps. I would just hate to see people pulling their plugs and decreasing the gap because they believe it creates a hotter spark. In fact it's just the opposite.
Cliff's Notes: Don't everybody tighten the gap in their spark plugs thinking it will always make the car run better.
Old Sep 12, 2010 | 10:10 AM
apexisilver8gsr's Avatar
plugs ??? kinda sounds like your timing breaks up
Old Sep 12, 2010 | 10:27 PM
ace442's Avatar
If its popping on throttle off then that means misfire, which means you should probably replace your plugs. I did it not long ago with some NGK platinum iridiums, it was worth it.
Old Sep 13, 2010 | 05:12 PM
rburris28's Avatar
As noted above, the problem was his MBC. I was just commenting on something I had seen several times about plug gaps.
michaelanjolo
Sep 16, 2015 09:27 AM
EvilTechnology
Jun 24, 2015 09:22 PM
n3m3sis
17
Feb 12, 2014 11:17 AM
black_beauty
48
Mar 19, 2013 08:11 AM
elhalisf
36
Nov 19, 2012 02:06 PM
