turbo flutter
Old Jul 7, 2010 | 10:41 PM
evo8turbo2000's Avatar
turbo flutter
i just took my car on a drive went full throttle right around 25psi i heard a flutter sound at around 7500-8500 rpm and lost power.the problem is intermitant i cant identify if it might be a wastegate issue or turbo issue. car has gt35r with 50mm tial bov and tial 44mm wastegate. car has never done this before and it does it wether i lower the boost or increase.
Old Jul 8, 2010 | 06:10 AM
wazzelby's Avatar
I would check for boost leaks and make sure all the vacuum lines are good. Maybe pull the intake and check the turbo for shaft play if you don't find any leaks.
Old Jul 8, 2010 | 09:13 AM
i did a boost leak test that checked out good. it sounds like a really bad misfire when im up really high in the rpms.
Old Jul 8, 2010 | 10:08 AM
wazzelby's Avatar
Could be spark blow out? Have you checked all your plugs? Maybe throw in a new set gapped correctly? Are you using anything to log with?
pog0
89
Dec 1, 2018 08:13 AM
J Yim
Jan 25, 2016 01:00 PM
05VIII
60
Jun 22, 2014 04:53 AM
sobo
Sep 28, 2011 11:28 PM
Eclipse4651
13
May 27, 2011 10:06 AM
