Exedy triple clutch Overhaul kit
Old Jul 10, 2010 | 11:52 PM
konstantinosIX's Avatar
Hello,
I am searching for an Exedy triple clutch Overhaul kit (3 discs and 2 floaters) in order to rebuilt my AMS triple metallic push style clutch.
Do you know where I could find it stock and ready for shipping?
I need it A.S.A.P.
I already talked to a buddy that I know he will try to find it FAST but if anyone knows any store that has it available for sale please help me!
Old Jul 11, 2010 | 12:26 AM
RSMike's Avatar
contact chriscarey from MAPerformance, i got my exedy parts through him Good luck!
Old Jul 11, 2010 | 08:15 AM
mrboost05's Avatar
http://paradigmperformance.net/index.html give him a call tommorow hes located right next to exedy and will take care of you.
Old Jul 12, 2010 | 04:34 AM
Searching on the forum I have been confused about the discs!!!!
The two new intermediate plates have the part number : IM02
The problem is with the 3 discs....
I have three different part numbers for the metallic discs...
3x DL03R or 3x DM11R or 3x DM15R
I do not know which part number is the right one!!!!
Could anyone help me????
Exedy catalogs from UK and US has only DL03R as the correct part number for discs repair.
So probably I need
Disks DL03R x 3
Intermediate Plates IM02 x 2
Searching now for someone who has the ready for shipping!!!!
Old Jul 12, 2010 | 05:42 AM
94AWDcoupe's Avatar
there are twp types of plates for the triple setup.
one type has three discs with each disc having its own hub splines that mate to input shaft.. the second type has a common intermediate hub. The hub goes on input shaft. and all the discs are splined to the common hub and not input shaft.
edit: DLO3R uses common hub (you will need common hub as well if your current discs are not this type)
DM11R = discs are splined directly to shaft.
DM15R is misprint. DM11R is correct part number?
https://www.evolutionm.net/forums/dr...onversion.html
Old Jul 12, 2010 | 09:10 AM
So which one is for AMS triple metallic clutch???
DL03R or DM11R ?
Old Jul 12, 2010 | 10:47 AM
OK.... I am sure now and
I am searching for
Intermediate Plates 2x IM02 and
Disks 3x DM11R
Any vendor that have them ready for shipping?????
Old Jul 19, 2010 | 07:50 AM
05blue8's Avatar
You won't find what you're looking for. Exedy no longer makes the disks with build in spline hubs due to a design issue. Talk to Evan at Exedy if in doubt, you need the spline hub, the three disks, and only the intermediate plates if yours are in really bad shape. Hope you found what you were looking for!
Old Jul 19, 2010 | 11:12 AM
scorch's Avatar
Had this same issue and all vendors stated they are on back order
Old Jul 19, 2010 | 11:21 AM
sho669's Avatar
^+1 I'm in the same boat...probably just gonna have to pony up and buy the whole tripple.
Old Jul 21, 2010 | 10:12 AM
Did anyone try to convert an Exedy triple carbon clutch kit to triple metallic??
Is it possible?
Old Jul 21, 2010 | 10:15 AM
sho669's Avatar
possibly...but the metallic kit is on backorder as well.
Old Jul 21, 2010 | 10:37 AM
What parts do I need to do that?
Did anyone ever try to convert it?
From the exedy catalog that I check.... every part has different P/N between carbon and metallic !!!!
vagelisix
Sep 23, 2013 07:06 AM
06redrocket
12
Dec 31, 2012 01:37 PM
konstantinosIX
13
Sep 25, 2011 12:51 PM
summercloud
Mar 8, 2010 06:37 PM
Nomad4g63
19
Oct 19, 2009 09:35 PM
