Need to find exedy triple rebuild kit.
There are people that sell the rebuild kits the part numbers are as follows:
Triple:
DL03R x 3 - friction plates
IM02 x 2 - floater plates
CH16 x 1 - center hub that the spline goes into (if you have an older version without the hub you will need this)
Optional Pressure Plate: PP02
You might want to replace your flywheel as well as the tolerances on these clutches are so tight that grinding it might not be good. Rebuilding these clutches is not cheap that's for sure. I did reuse my flywheel without grinding once and my first two clutches went a combined 75,000 miles. My first clutch went around 45k and the second one 30k so the reused flywheel might have shortened the life a bit.
Triple:
Has everybody gotten too lazy to search? https://www.evolutionm.net/forums/ev...riple-kit.html
I found that in less than 30 seconds......
FS[Northeast]: Exedy Triple for rebuild
My03evo
May 17, 2016 11:34 AM
WTB[Northeast]: Looking for Exedy Twin disk rebuild kit
DuBBzEvo27
Jul 21, 2015 11:37 AM
turbo speedy
10
Dec 13, 2012 07:00 PM
AcePitcher11
28
Jun 22, 2010 01:29 AM
