Need input what is the best head gasket when boosting 2.3 bar?
Again, the head gaskets you are blowing are proven parts. The studs you are using are proven with the correct 108-110 nm torque, assuming you are torquing them in the correct sequence and with the ARP lubricating grease. There are plenty of people who have made far more power than you or me over the years with ARP 2000s and the correct torque.
4-20sx (Feb 4, 2018)
ARP torque settings represent 75% yield of the fastener itself (according to ARP). That means the static preload itself applies 75% of the force required to cause the stud to stretch or just plain fail. If the OP is using the incorrect torque specified for that particular fastener(?), that would represent human error.
1 Post
Originally Posted by Stradale
Ok .. so at least it is better to torque those stud to 95 lbs right?
Originally Posted by TedB
..... I recommend making no assumptions from memory, and double checking what is specified on the sheet that comes in every box.
lghtngyello03
Mar 19, 2016 04:25 PM
eus_evo8MR
Feb 13, 2013 10:20 AM
