RC 1000's vs PTE 1000's
Old Jul 15, 2010 | 03:11 PM
5LEEPERISAH23I's Avatar
are they both good injectors?
Old Jul 15, 2010 | 03:13 PM
RockmanX's Avatar
I know PTE is gangster i dont see to many folks rocking Rc injectors but PTE and FIC for sure.
Old Jul 15, 2010 | 03:23 PM
boostedtres's Avatar
i agree. PTE and FIC are great injectors, know a couple people running them on blacks making good, safe, reliable power on stock motors. im actually planning on doing the same build, so keep me posted! gl with the build
Old Jul 15, 2010 | 03:27 PM
will do
Old Jul 15, 2010 | 04:11 PM
AlwaysinBoost's Avatar
been running RC1000 since 06, aprox 60k miles with no issues. I'd say they're fine.
Old Jul 15, 2010 | 04:26 PM
Svendiesel's Avatar
Got PTE 1200's for my build, win
Old Jul 15, 2010 | 04:27 PM
xsolowx's Avatar
A caution note...if you have any plans on running e85,rc's are not compatible.if u still are considering them I have a set ill let go for a deal...they just need lower seals. I swapped out for the fic's and love em....
Old Jul 15, 2010 | 04:33 PM
KenMasters's Avatar
^??? Been running rcs on e85 for ever. You are misinformed.
Old Jul 15, 2010 | 04:49 PM
Ted B's Avatar
No matter whose name is on it, if the injector is a pintle type - that means if it has what looks like a large metal pin protruding from the tip, you do NOT want to use it with E85. Why? It isn't the E85, but the residue that it can leave behind that positively compromises a pintle type injector, and has caused the death of more than one engine as of late.
The ball type injectors are relatively unaffected.
FYI
Old Jul 15, 2010 | 04:54 PM
excellent info as usual Ted, thanks.
Old Jul 15, 2010 | 04:55 PM
atkins's Avatar
have been running 750 rc's for a while and just bought 1000s to run when i go bigger turbo, no problems here.
jeff
Old Jul 15, 2010 | 04:56 PM
xsolowx's Avatar
Info came directly from RC, tech support.
Old Jul 15, 2010 | 05:11 PM
xsolowx's Avatar
FYI
+1 I didn't have any issue with buildup, but the seals included did not like e85. Within a couple days of switching, developed one heck of a boost leak at the injector seals. When I took them out, there was definite signs of deterioration of the seals. After researching I decided to get the fic since they are a ball type rather than just putting the viton seal kit on the rc's.
Old Jul 15, 2010 | 06:12 PM
project_skyline's Avatar
I have no issue with my RC1000's on e85, been running them for over 40k miles.
Old Jul 15, 2010 | 06:39 PM
Ted B's Avatar
Ok, but not everyone been so lucky. If one in 20 loses an engine, it's unacceptable.
Again, I strongly recommend avoiding any pintle type injector with E85. There is no good reason to use them when other types fare better.
