bad fuel injectors?
bad fuel injectors?
so i had my rear o2 sensor out so i didnt think twice when my check engine light was on but then my car was runin a bit rough after a while i put it back in and made the spacer out of the spark plug spacer thing so i wont get to much air on the o2 but after i did the car was runin even worse so i got the test from autozone and its a random cyl missfire. in the past 6mon ive replaced the spark plugs and wires
i can hear a ticking comin form the engine thought it might be some sort of arc comin form the ignition spark area but after a closer listen sounds like its comin form the intake manifold/fuel system area. so im thinkin its a bad injector? all vacum lines are on. i heard I can check the injector with a multimetor thing how to i check the injector with that? any ideas what it might be besides a fuel injector.
i dont want to pull the spark plugs for no reason cuz i messed up the conector part of the wires last time even thow i ws pullin form the base .
PLZ HELP I cant afford to pay a shop now and cant stand my baby in pain like this
PS. u can tell the missfire when i first start it up when i let it warm up it gets better and when im goin slow in 1st it feels like im almost tapin on the gas a lil bit when im stedy on it. but when drivin over like 10mph it seems to drive just fine but also when i stop at a light theres alot of viberaton (i have a tourqe damper but its worse than ever) and if i try and turn on the AC it gets real bad so i have to just leave it off
well i just went back to vatozone to get the code and its P0300. when i took it in a few days ago they said one random cyl and now this guy said its multi cyl. damn I have the OEM ignition system and i know its like coil over plug then goes from coil with wire to the 2nd plug so would it be a bad coil pac to be hitin 2cyl like that?
ziad
Jun 12, 2012 08:22 PM
BOOST_ADDICT
Northwest Region
38
Jan 17, 2012 03:06 PM
