MAP ultimate duty VS Manley TT rods
Old Nov 7, 2011 | 09:13 PM
RSGuy's Avatar
The Manley TT I beams are obscenely heavy, though. They are great for extreme power/boost levels but I'd rather go with a lighter, Professional level H-beam rod (RR/Carrillo). A lighter rotating assembly means easier revs, higher rpm's, and most importantly- less wear and abuse on your bearings and crankshaft.
Old Nov 7, 2011 | 09:24 PM
EvoPauly's Avatar
Originally Posted by Ginglingston11
ive always heard the TT were unbelievable rods until Adam from MAP sent me a pic of a rod that was destroyed...so idk what to believe
your going by what one person said, not only that he is also trying to sale his product. Most people run the TT They proven over and over
Old Nov 7, 2011 | 09:29 PM
WHTEVO's Avatar
Can't go wrong with the TT rods. I used them in my high HP build, and they were fine.
Aaron
Old Nov 7, 2011 | 10:37 PM
Broham's Avatar
I agree with you here. The TT has proven itself many times to be real solid and strong, so a failure is not really a common thing. A billet oliver rod, or carrillo pro h beam with the 3/8" bolts are also very strong. No worries about the turbo tuff rod. It's not going to break until y ou are over 900 whp probably
Old Nov 8, 2011 | 07:15 AM
SmurfZilla's Avatar
You almost make it sound liek the TT's are so heavy your bearings are going to fail in short order.
They are heavier then their aluminum counter-parts but they've been proven in terms of abuse they can take and longevity.
And on the TT rod that failed MAP, what was the story behind. it doesn't matter if something is made out of Titainium, Adamantium or UnObtainium......if exposed to high enough pressure anything can fail.
Old Nov 8, 2011 | 10:25 AM
Silk's Avatar
Blew the line of my wastegate, spiked 50+ lbs and did this to my MAP rod... smhh
Attached Thumbnails MAP ultimate duty VS Manley TT rods-287116_10150730339810632_704080631_19764091_176819_o.jpg
Old Nov 8, 2011 | 11:58 AM
acssa's Avatar
Wow!
Originally Posted by silk
blew the line of my wastegate, spiked 50+ lbs and did this to my map rod... Smhh
Old Nov 8, 2011 | 12:35 PM
BigT's Avatar
Better than it snapping on you and putting a hole in your block.
Old Nov 8, 2011 | 12:40 PM
Broham's Avatar
IT's unfortunate what happened, but the fact it bent shows it was well made as even a billet rod will bend. It's when it shoots out the block To "window" that its a real problem
Old Nov 8, 2011 | 02:46 PM
Erik@MIL.SPEC's Avatar
I think that would be called a "good" failure, no?
Old Nov 8, 2011 | 03:35 PM
RpoSti06's Avatar
Manley TT are great for High Hp cars but like others have stated they are heavy
Old Nov 8, 2011 | 03:36 PM
n2oiroc's Avatar
i'd say so.
Old Nov 8, 2011 | 03:55 PM
Silk's Avatar
Indeed a good failure, only drawback is its taken forever to get the single replacement rod.
Old Nov 8, 2011 | 04:07 PM
longdingydong's Avatar
i waited 5 months for the map rods. finally just bought some manley tts and havent looked back. all the research i did, im pleased with decision so far
Old Nov 8, 2011 | 04:16 PM
ChrisCarey's Avatar
In my opinion you can't go wrong with either guys, as outlined above every rod *can* fail depending on the amount of abuse it is put through lol.
