MAP ultimate duty VS Manley TT rods
I would like some updates please.
I know it’s 2019 but I can’t find more reviews on these 2 rods. I know the map rods are now the rev2 rods. If anyone out there can give me more info on their experiences I would greatly appreciate it. Thanks in advance.
My car:
Evo 9 mr stock 6 speed
stock 9 head w/ stock valvetrain
hks exhaust camshaft (idk which one prob 272)
custom 35r turbo kit
Arp headbolts
full bolt ons
walbro 450
e85
30 psi
Hoping to be at 500awhp and close to 500tq
fic 1450
My car:
Arp headbolts
full bolt ons
walbro 450
e85
30 psi
fic 1450
Both are solid rods and will suit your power goals so go with whatever fits your budget. I do believe the Howard rods require 6 bolt bearings which is why it states it should be used with an oem crank but your builder will sort out the necessary clearancing.
The price isn’t the issue because I’ve already paid for the stage 2 block to be built. I’m just more concerned about reliability since the Manley’s don’t have very many poor reviews as the map rods have a few poor reviews.
Get your money back before MAP builds you an engine, then go buy an engine from a shop that actually knows that they're doing. This is but one example of a failed MAP engine- rings upside down FTW. Read from this post onward.
https://www.evolutionm.net/forums/pr...l#post11729117
I can’t build it bec I don’t trust myself because I’m not good with numbers and calculations. It’s a bit too sensitive for me. I can’t afford to mess it up myself rite now. Maybe I’ll start building a cheaper motor in the future. Like a civic motor or something like that.
Hey @letsgetthisdone, this is the same build they faked the blueprint sheet on well, right?
A local guy with an EvoX has a MAP motor. It doesn't seem to use oil or smoke, but it sounds he did a cummins 4bt swap with all the noise the engine makes....
RichK@AMS
Automotosports - Illinois
21
Jul 25, 2007 11:20 AM
