GSC S3 cam broke
Old Aug 15, 2010 | 01:50 PM
  #61
OneCrzyEvo21's Avatar
Originally Posted by GregGSC
Sounds to me like you were tighting down the cam caps with the cam not seated correctly. The extra tension on the cam can cause the shaft to snap (it is a cast shaft). I haven't seen or heard of an issues with the I4 cams having a problem on install, but i will tell you the longer I6 (2JZ or RB) cams we have people break them all the time on install. Please give me a call on monday and we will get you a single intake cam.
+1 Speak about customer Service..
Old Aug 15, 2010 | 01:59 PM
  #62
4doorstreetbike's Avatar
Originally Posted by CammedEvo
GSC CAMS ARE NEW BILLETS!!!!!!!!!!!!WRONG EXAMPLE.YOU KNOW HOW MANY SHOPS SLAP CAMS IN AND GO ON THE DYNO TO MANY TO LIST.
Old Aug 15, 2010 | 02:01 PM
  #63
mrtalon20's Avatar
Customer service, ill let you all know how things go on monday. From the way things soujnd it should go grreat on monday when i talk to greg.
Old Aug 15, 2010 | 02:02 PM
  #64
Ev0ikon's Avatar
Just a question but were they dual springs new? You know you're GSC s3 card says that breakin should be done on the outer spring only right
Is there a digital version avail? I got a lot to read up on then.
Old Aug 15, 2010 | 03:55 PM
  #65
GregGSC's Avatar
I've never seen a thread blow up like this has for no reason at all... this engine has never run. it wasnt a faulty camshaft it wasn't a mivec engine. It is simply tightning down the cam caps with the cam rotated incorrectly. like i said in my first post its a common problem on longer camshafts and it does happen. Heck As many camshafts as i handle i've actually done this same thing with a 2JZ cams before.
Old Aug 15, 2010 | 05:17 PM
  #66
RSMike's Avatar
Greg, for the other forum members, could you please explain the correct rotation the cam should be in for a cam install. So that everyone following this thread knows how to avoid this accident etc
Old Aug 15, 2010 | 06:20 PM
  #67
mrtalon20's Avatar
I really didnt think it would blow up like this the cams are good just ran into that one little problem but greg said he would get me another intake cam im cool. Ill buy gsc cams all day. So dont take my problem and think the cams are bad stuff happens all the time. Thanks Greg.
Old Aug 15, 2010 | 07:03 PM
  #68
bbyevo8u's Avatar
Originally Posted by mrtalon20
Zero miles Just installed them.
was the engine running?
Old Aug 15, 2010 | 07:41 PM
  #69
cij911's Avatar
Greg - Great of you to come in and comment and provide support . Can you explain what has changed with the 'new" MIVEC cams to address the earlier failures ? Thanks !
Chris
Old Aug 15, 2010 | 07:49 PM
  #70
RSMike's Avatar
dont you read threads before posting?
it happened while installing them, the engine did not turn.
Old Aug 15, 2010 | 08:07 PM
  #71
Ev0ikon's Avatar
Yeah... People installing cams with the engine running all the time!
There is no "rotation" going on at all. You make sure the dowel rod sticking straight up and the caps should not be binding while being "walked" down.
Old Aug 15, 2010 | 08:13 PM
  #72
reactionevo8's Avatar
i love threads like this because it gives companies to really show their true colors....i wouldn't hesitate to buy any gsc products in the future because from what i can tell they have outstanding customer sevice
Old Aug 15, 2010 | 11:09 PM
  #73
project_skyline's Avatar
i'm willing to bet this is because of the standalone added time to start.
its vital that on initial start up the car fire up instantly and you rev to 1800-2000 to ensure oiling.
Oh brother... do you even know what your talking about?
Old Aug 16, 2010 | 02:08 AM
  #74
mrtalon20's Avatar
Old Aug 16, 2010 | 05:07 AM
  #75
GregGSC's Avatar
I have an evo 8 long block engine i'm building this week. i will snap a few pictures of how we install cams. for one we do not use TDC on the crank when installing the cams do to the rotation of the cam. i will post something up in our section on friday.
