what the hell is this noise?
Old Oct 1, 2010 | 03:02 PM
  #121
tscompusa2's Avatar
Originally Posted by boostedwrx
tscomp go check ur oil bro!
burned a quarter quart lol. expected with a new motor as the rings seal.
Old Oct 1, 2010 | 03:30 PM
  #122
apagan01's Avatar
tscomp-
have you concidered running a racing oil like Racing dominator 15W50,,, loaded with zinc and phos helps a little with those touching metal to metal surfaces,,,, i know you been using 20W50 though,, i would like to see a higher zinc and phos oil in the race motor
Old Oct 1, 2010 | 03:31 PM
  #123
tscompusa2's Avatar
Originally Posted by apagan01
tscomp-
Maybe. I am gonna use the rest of this 20w50 amsoil first though. I have 3 boxes of it
RIght now im using garbage oil for break in. (non synthetic) autozone and advanced auto parts oil
Old Oct 2, 2010 | 06:45 AM
  #124
apagan01's Avatar
keeep that engine alive
Old Oct 2, 2010 | 11:01 AM
  #125
RockmanX's Avatar
lets hope you dont total this one boss. if you dont mind pm me how much it cost you to bring it back to life again now that its said and done. Also just curious if you gernaded this one early again would you do this again or let it go??
Old Oct 2, 2010 | 12:01 PM
  #126
tscompusa2's Avatar
I did not total it or grenade it. The motor burned 3-4 qts of oil on a long trip from pa to oh and i didnt check the oil and it was to late and spun a rod bearing. it only had 5k on it and from my research running at the same speed for over 500 miles is the worst thing you can do to a new engine.
The motor still is using the
same pistons
same rods
same block
It just needed a new crank, new bearings. Its using the same head also.
was 1k for repair and ill pm you price of oem hardware.
Old Oct 2, 2010 | 12:11 PM
  #127
RockmanX's Avatar
same pistons
same rods
same block
cool i know you did not gernade it fiqure of speech. btw i posted those pics of Z in my thread for you boss
Old Oct 2, 2010 | 12:58 PM
  #128
tscompusa2's Avatar
nice will check it out man. ya , i figured.. just didnt want people thinking i grenaded it lol so i had to correct you
Old Oct 2, 2010 | 04:18 PM
  #129
red03evo's Avatar
good to see you got the car running again
Old Oct 2, 2010 | 04:46 PM
  #130
cij911's Avatar
Why are you burning oil on a new engine ??? I really don't understand this....
Granted I have not built my Evo motor yet, but every other motor that I have built did not leak or burn any oil...
Old Oct 2, 2010 | 05:58 PM
  #131
apagan01's Avatar
Chris-
A little blow by here and there
Old Oct 2, 2010 | 06:35 PM
  #132
tscompusa2's Avatar
ill post a vid of it running tomorrow.. it really sounds so much better. before there had to be air in lifters.
Old Oct 3, 2010 | 09:37 PM
  #133
tscompusa2's Avatar
heres video i said id post. http://www.youtube.com/watch?v=VBaW3PzKbMQ
need to log this. feels awful strong for 25psi. its 25psi creeping to 30, but i wouldn't be surprised if it shows 550+ now.
Old Oct 3, 2010 | 09:46 PM
  #134
Evoryder's Avatar
why you using non brand oil on your motor? Even for break in?
Old Oct 3, 2010 | 09:54 PM
  #135
tscompusa2's Avatar
****s all the same. you're not supposed to break a motor in with synthetic oil. the only thing that will complain is the turbo, which is why i have it running off wastegate pressure right now.
I used autozone, advanced auto, and i have valvoline also. all conventional oils are the same for the most part. after the valvoline im gonna put the amsoil back in. whatever im doing is working.. it already has 10-15psi more compression across then the old motor did. no point in using good oil when you're changing it in 15-25 miles. the idea is to change it and get the metal deposits out of the oil.
Balrok
Apr 19, 2016 10:47 AM
staticstance
Nov 29, 2015 07:55 AM
smokedmustang
103
May 11, 2006 08:19 AM
smokedmustang
23
May 9, 2006 09:40 AM
Blacksheepdj
Lancer How Tos / Installations
Apr 7, 2004 05:33 PM
