Blow off Valve help please!!!!!!!!1
Old Nov 24, 2003 | 10:29 AM
evo8power's Avatar
Question Blow off Valve help please!!!!!!!!1
I have the turbo xs h34 bov, i have all 6 washers in it and it seemd like when i let of the gas at full throttle the car gets jerky and doesnt feel right, also when i am at full throttle then shift, the car revs between shifts.If anyone has any info on these valves or has one let me know how many washers your using and if u have the same problem?????
Old Nov 24, 2003 | 11:52 AM
evolutionist's Avatar
Re: Blow off Valve help please!!!!!!!!1
Originally posted by evo8power
I have the turbo xs h34 bov, i have all 6 washers in it and it seemd like when i let of the gas at full throttle the car is jerky??
Holy crap. All six washers, that is a stack! I am running that valve and 22 psi in the second boost setting on my EBC. I have just the spring in and it holds just fine. It is as smooth as they come at any speed. I would suggest starting with no washers. If you hear a leak, make sure it is not coming from the hoses first before you go and increase the spring resistance with washers.
I would not be suprised if you will now have a leak with no washers considering you have compressed your spring up so tight.
The idea of the spring tension is to have it just tight enough to hold the boost while having the spring light enough to release for drivablity.
It will hold with six washers like a mother, but it has so much tension it won't release. That is why your car is bucking, the air is still slamming into your intake after you have let off the gas.
I am no expert at this, just gone through this with other products. Try no washers or one, or two.
Old Nov 24, 2003 | 02:31 PM
evo8power's Avatar
thanks man im gonna give no washers a try, my xede is tunned for 22 psi so hopefully i will be in the same boat as you...i heard its a good valve just problems with the right settings. Thanks a lot!!
Old Nov 24, 2003 | 09:01 PM
GTVEVO's Avatar
I have the H34 as well and you only use the washers if you plan on venting to the atomsphere. Take out all the washers and you will be fine.
Old Nov 25, 2003 | 05:10 AM
evo8power's Avatar
thansks!
MechNARP
24
Oct 10, 2017 06:52 AM
ak47po
33
Mar 21, 2016 11:31 AM
evo8power
21
Jan 10, 2016 12:07 PM
D2003
Jan 4, 2016 05:35 PM
turboDan
86
Oct 26, 2012 12:47 AM
