Please Advise on my Evo 5 Shaft...
Old Sep 4, 2010 | 05:42 AM
jameswwt's Avatar
Please Advise on my Evo 5 Balance Shaft.
Hi guys,
just wonder do we need polishing to the balance shaft journal?
Im rebuilding my evo 5 engine due to a fail rod bearing.
I noticed my balance shaft journal condition is about the same as my cranks journal after a burnt rod bearing. What should i need to do? Do i need to replace the 2 balance shaft?
I also noticed there are bearings exactly like the main and rod bearing.
Or i just need to change the balance shaft bearing?
Please advise.
Old Sep 4, 2010 | 05:54 AM
meckert's Avatar
If you threw a rod bearing--everything touched by contaminated oil needs to be changed or reground...so yes have a machine shop look at the shaft and absolutly change the bearings. A short cut now will cost much more later if it fails.
Old Sep 4, 2010 | 07:28 AM
jameswwt's Avatar
Thanks Meckert...But i thought when i purchased the ACL bearings for the main & rod its already comes in the package?
Will it be difficult to find the balance shaft "U" type bearings?
Old Sep 4, 2010 | 08:38 AM
94AWDcoupe's Avatar
check that surface carefully. usually the shaft is ruined if there was bearing wear. the shaft is heavy on one side when it rotates. so the wear occurs on the heavy side. this means its no longer round and not usable.
Old Sep 4, 2010 | 08:53 AM
jameswwt's Avatar
Thanks Man, but which to replace since thereb are equipped with 2 balance shafts. The left balance shaft that's directly connected to the oil pump driven gear and the right balance shaft that's driven by the balance shaft belt over the oil pump sprocket???
Can i send the current oem balance shaft for polishing or should i go for the balance shaft eliminator kit??? But still,which 1 to be replace by the kit?
Old Sep 4, 2010 | 02:07 PM
RSMike's Avatar
i think what 94awdcoupe was saying is you need to measure the balance shaft that spun the bearing.
If it's not circular anymore (from uneven wear) then you need to bin it. i.e. there is no point polishing a balance shaft that is beyond repair.
Then you need to decide if you want to replace it with a 2nd hand item, new, or remove them all together. There are countless threads talking about balance shaft removals. You should talk to your engine builder and find out which is best for you.
Cheers, Mike
Old Sep 5, 2010 | 01:17 AM
jameswwt's Avatar
Cheers, Mike
Thanks Mike and for yr personal opinion, what do you suggest???
1) Replace the oem bs to mitubishi oem bs eliminator stub kit (but there are 2 shafts and which to replace? both?)
2) Polish the current 2 mit oem bs and change the rear & front bearings only???
Pls advise...
Old Sep 5, 2010 | 01:26 AM
Roadrunr's Avatar
If you decide not to delete the Balance Shafts. I have new shafts off a new Evo IX I will ship you for the price of shipping.
Don
Old Sep 5, 2010 | 03:07 AM
jameswwt's Avatar
Don
But im in Malaysia.
If you really dont mind,can you quote me the price to Petaling Jaya 46000, Selangor Malaysia.
Thank you.
Old Sep 5, 2010 | 06:12 AM
Roadrunr's Avatar
Originally Posted by jameswwt
But im in Malaysia.
Thank you.
Please verify they are the same. Should be as they are both a 4G63. Is there anything else you need from the US that is not available.
Don
Priority Mail® International Medium Flat Rate BoxInternational Medium Flat Rate Box]
USPS Supplied Medium Box:
13 5/8" x 11 7/8" x 3 3/8" or 11" x 8 1/2" x 5 1/2".
Maximum weight 20 pounds.
6 - 10 business days
$43.45
Old Sep 5, 2010 | 08:47 AM
jameswwt's Avatar
Don
$43.45
Hi,i think ive got all the stuffs i needed from states (gsc s2 cams / acl main & rods bearings / arp head studs).
But how can i do the payment? can i pay via paypal? I have few american church friends over here as well....
Thanks Don.
Old Sep 5, 2010 | 10:17 AM
Roadrunr's Avatar
Thanks Don.
Give me your full address and I will ship on Tuesday. I will PM you with the exact amount. Pay Pal is fine.
Don
Old Sep 5, 2010 | 05:47 PM
jameswwt's Avatar
Don
Hi Don, before that can you send me some pics of the BS to jameswwt@hotmail.com before you send the stuffs.
Thanks
Old Sep 5, 2010 | 06:54 PM
94AWDcoupe's Avatar
I would take Don up on his gracious offer. I dont like deleting the shafts.
DEA
Jun 16, 2015 04:10 PM
mines5
45
Dec 7, 2013 01:32 PM
mnf
Jan 16, 2011 06:16 AM
jameswwt
Sep 5, 2010 08:47 PM
2JZfan
Automotosports - Illinois
Sep 19, 2007 10:53 PM
