Need some suggestion, mbc or electronic boost controller
Hey guys my car is getting built, and will be leaving with a manual controller attached. I am getting tuned on e85 and 93, with a toggle switch put on so I can put it on the correct map for the fuel I put in. But, If I have 93 in, then put e85 in, I need to change the boost level. I dont have any experience with manual or electronic controllers. I think for me it would be easiest to get a simple buy yet good electronic, so I dont have to mess with the manual. I know electronis can be a p.i.t.a. to set up correctly. This is why I am asking you guys for advice. any suggestions, this car is not daily driven, will only be driven a couple times a month. Im going with a 2.3 fp black set up
buschur dual stage boost controller:
https://secure.buschurracing.com/cat...oducts_id=1250
Guys you are missing the point - he will be doing map switching ! Without a doubt just use the Tephra v7 mod and control boost with the Ecu. Your pump tune will have your pump boost profile and your e85 will have your e85 boost profile.
With you setup the MBC is NOT the right choice.
Well if you can read and you can find a good tuner, you'll be fine....It's pretty basic - just find a tuner that works with the Tephra v7 mod.
jag0
16
Aug 15, 2010 07:57 PM
