need help once more
Old Sep 19, 2010 | 02:56 PM
Spanishevo's Avatar
Unhappy need help once more
hey guys i need help and hopefully some answers again. my car started making a ticking noise yesterday i think its the valves mayb the lifters so i ran some valve medic in it and that didnt help then put some seafoam in it also still didnt help. i cant hear the noise at idle i only hear it when im holdin a constant speed in my car and maybe pushing down on the pedal slightly (this happens at any rpms as long as im not pushin the pedal too much) but then when i accelerate more the noise isnt there or maybe the car is too loud for me to hear it. AND also when i accelerate normally i push the pedal slightly it boosts about 5 pounds i can feel the power fine but when i accelerate more to where the turbo is spooling up past 10 psi i feel like something is holding the car back instead of accelerating at the 24 psi like it should so please help!
Old Sep 19, 2010 | 03:06 PM
WHTEVO's Avatar
Possible rod knock? You could drain your oil and see what it looks like. Rod knock will sound like it is coming from the valve cover area. Good luck.
Aaron
Old Sep 19, 2010 | 03:09 PM
Spanishevo's Avatar
yea it does sound like its coming from the valve cover area and what would i look for in my oil?
Old Sep 19, 2010 | 03:33 PM
XdsEVO8X's Avatar
look for sparkly metal in your oil, it sounds like rod knock from what you described.
Old Sep 19, 2010 | 03:38 PM
Spanishevo's Avatar
aight cool im probably gonna change the oil tomoro then post back but do u have any idea y my car would feel like it doesnt want to accelerate in high psi?
Old Sep 19, 2010 | 03:43 PM
XdsEVO8X's Avatar
you could have a boost leak or knock and your ecu is pullin timing.
Old Sep 19, 2010 | 03:48 PM
Spanishevo's Avatar
the thing is that it reaches full boost but it feels like the car is being held back. at 5 psi the car is accelerating fine but once the boost is at peak or on its way there it feels like the power isnt there its tuned at 393 hp
Old Sep 19, 2010 | 03:52 PM
buchnerj's Avatar
If you are knocking then the car will pull timing automatically if you are on the stock ECU and thus feel like something is "holding it back". Sounds like either a lifter problem or rod knock. Do you have a version of the tehpraMOD and does your CEL flash on knock? Take a log of the problem and log boost, afr, knock sum and timing. Only then can you figure out what is really the issue.
Old Sep 19, 2010 | 03:59 PM
Spanishevo's Avatar
my cel hasnt been flashin and i dont have the tehpraMOD but i do have a friend that can log all that so ima ask him for his help thanks
Old Sep 19, 2010 | 04:21 PM
XdsEVO8X's Avatar
your ecu is pullin timing due to knock i had the same issue with my car due to a loose motor mount. it hit full boost but didnt really pick up speed as it did before.
have your buddy log your car so you know fer sure what it is
Old Sep 19, 2010 | 06:07 PM
Spanishevo's Avatar
thanks man ill post wen i learn more
MitsuJDM
44
Dec 18, 2012 06:48 AM
Jwarian
Lancer Troubleshooting
May 12, 2011 01:26 AM
Spanishevo
24
Feb 15, 2011 12:09 PM
nick735
Jul 9, 2004 06:32 PM
batdorf9
Oct 16, 2001 05:25 PM
